Included pad
I'm new to DA polishing and have yet to do it... I bought a 7424XP which came in about mid week. I still need to invest some money into pads before I try to do a correction job to either of our vehicles; 2 LC CCS pads were included - orange & gray.
Having said that, the 7424XP also came with the standard PC white polishing pad as well. I was thinking about trying out this pad with DP Glass Restorer. I figured this may be a way for me to play with the DA a bit, get a feel for the pressure needed to spin the pad, while not having to touch any paint. Possibly even dedicating this pad for glass polishing... thoughts?
McKee's 37 Product Support
Re: Included pad
Here's some helpful information on that pad.
The white foam pad that comes with a Porter Cable Polisher
For years I've seen people post questions about the white foam buffing pad that comes with a Porter Cable DA Polisher and I've also seen some confusion over whether or not a person needs to order a dedicated backing plate with the tool?
So here's the skinny, the white pad in the box,
- Is a Polishing Pad, not a cutting pad or a finishing pad
- Has a fixed backing plate that is glued to the foam, it cannot be detached and used with other pads
- Measures approximately 6" in diameter and is 1.5" thick
Porter Cable 7424XP brand new in the box...
Here's the included white foam polishing pad...
Here's the glued-on plastic backing plate...
Re: Included pad
Thanks Nick. I did a quick search before posting, but didn't find the thread you linked.
I figured as much regarding investing in pads for polishing paints and that's exactly what I intend to do. I just figured I could play with it a bit on the glass first while I don't have all of the other pads just yet...
By bossmustang16 in forum Wool & Foam Buffing Pads
Last Post: 02-26-2015, 04:37 PM
By Darion in forum Auto Detailing 101
Last Post: 03-10-2014, 06:16 PM
By mbc4934 in forum Ask your detailing questions!
Last Post: 06-05-2012, 07:56 AM
By DrMcDave in forum Ask your detailing questions!
Last Post: 10-01-2010, 09:21 AM
By asterisk in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 07-28-2010, 08:24 PM
