PC problems
I own a Porter Cable DA with a Mequirs backing plate. Using 6" Hybrid pads. After using it for a minute or two the backing plate becomes loose from the PC almost like it is spinning in reverse. Any ideas what I could be doing wrong.
Thanks
Re: PC problems
Notice that Lake County sells a compression washer to go between the backing plate and the PC. I do not have a washer between the two with current setup. Could this be causing my problem?
Thanks
Re: PC problems
Thanks
In a word...yes.
You can take a run to your local hardware store, head for the plumbing isle, find a fiber washer that's about an 1/8" thick and about 1/2" diameter. Probably run ya about 50 cents or so.
That &^%* washer is a must!
Good luck and welcome to AGO!
Bill
Re: PC problems
Welcome!
Yup, you need the washer.
Re: PC problems
yep, if I remember correctly that washer has to be in there. I vaguely remember having a difficult time removing my backing plate once after forgetting to put the washer in. It makes fitting the wrench between the backing plate and polisher very difficult. I don't know how I tightened the pad on so far, without the washer, in the first place. oh well
Jeremy Wayne
Re: PC problems
I actually use two washers. One comes with the PC and the one supplied with the LC backing plates.
By pmg in forum Off-Topic
Last Post: 12-26-2013, 01:40 AM
By pointillistic_practitioner in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-04-2011, 03:24 PM
By scjshaylen in forum Auto Detailing 101
Last Post: 07-19-2010, 06:59 PM
By Integra-S in forum Auto Detailing 101
Last Post: 06-04-2010, 01:35 PM
By nrengle in forum Auto Detailing 101
Last Post: 01-06-2009, 02:11 AM
