09-20-2013, 05:00 PM
#541
Re: Harbor Freight DA Polisher - New
Originally Posted by beamerstrumpet
Not sure if yoru trying to be funny or not.
@ Mikesal57 Works great out of box as stated by others. all mods noted on page 46 and maybe a few b4 that. also pictures on how to add a longer cord to it in a listed link. or look for HF cord upgrade by me.
as long as you ditch the original backing plate, you should be G2G!
I forgot that part. I needed to replace mine. As most of my pads are 5 1/2" I went with 5 inch plate.
Fred R. Elias Jr.
Warren, MI. 48091
1-586-755-1245
09-22-2013, 09:04 AM
#542
Is Valvoline General Multi-Purpose Grease OK to use?
Theres one rated to 250 degrees
and another to 400 degrees
Might the 400 be too thick?
09-24-2013, 04:15 PM
#543
I dont see why not. I do know from personalexpeirance that bearing grease is too thick. If its not a heavy grease, it should be good.
09-26-2013, 08:42 PM
#544
How much of a difference you think it makes by doing this grease mod. I want to do it as well just gotta try to get the right grease and from where
09-27-2013, 05:16 PM
#545
From all reports its quieter and stays cooler. Its not necessary, but it dont hurt either. I really like the longer cord I instaled also! I have not done to much since I got mine all done out. hoping to get something done this weekend.
09-30-2013, 03:04 PM
#546
Well I just finished doing the grease lube to one of these, and it was super easy.
One heads up I'd share is about the typical HFT quality of the fasteners - the flathead phillips screws that hold the shroud on were partially head-stripped (aka the screwdriver slots stripped not the threads) a little even before I touched them.
Being a clever lad of experienced years I had no issue removing them but I insisted on replacing them w/ hw store replacements (4mm BTW). A little blue loctite as well and they should be completely fine.
Sadly between the relube time and some other chores, my window to give it a practice shot evaporated yesterday afternoon - the car in the blocks ended up only getting a wash and wax refresh instead of an actual polishing and reseal. So real first impressions won't be for a while...
Originally Posted by lucky417
is there a way to just put some grease in the hole where u put the allen wrench at?
I had already been thinking about if a grease fitting would fit there (answer yes of course anything is possible but I mean easily... ) and if so I might try to top-off a little bit to really pack the grease in there... Problem is the red plastic grip-cover wouldn't fit on afterwards so you'd have to screw the grease fitting in, then remove it and tape or plug afterwards....
09-30-2013, 03:39 PM
#547
Lucky417
Yes there is a way to put grease in that hole.
PM me and I will tell you how
At some point I would be taking photos and posting
10-01-2013, 01:08 AM
#548
So I def leaning more towards just doing the grease mod. I mean why not. If everyone is having great success by Doing it. And hey if it doesn't hurt why not. If its going to make run quiet and smoother/cooler. Perfect.
So I'm sure this has been answered 100 times. Abugt what type of grease do you guys suggest I use. And where can I get it. Sorry I just am a little lazy to look through the threads pages at the moment.
10-01-2013, 10:47 AM
#549
I think it's the pic I posted here (post #510): http://www.autogeekonline.net/forum/...tml#post944848
10-01-2013, 02:08 PM
#550
So pretty much you just take the bp off then take off the 4 screws and take it apart cleannas much grease off as you can then re pack and put screws back on then your good to go??
By SoreArms in forum Auto Detailing 101
Last Post: 05-28-2019, 08:53 PM
By DaneMcWilliams in forum Auto Detailing Tools and Accessories
Last Post: 08-14-2018, 03:27 PM
By yamaharider529 in forum Auto Detailing Tools and Accessories
Last Post: 09-29-2017, 02:27 AM
By Supergus1 in forum Ask your detailing questions!
Last Post: 12-04-2014, 08:04 PM
By jstevens66 in forum Auto Detailing Tools and Accessories
Last Post: 05-09-2014, 03:39 PM
