Everything I have been reading about the popular set up on the 7424XP is using a 5” backing plate. The counter weight on mine says 6” on it. I could only find a 6” backing plate locally and used a 6 ˝” Maguire’s pads to get some work done on my 2005 White Toyota. It seemed to work fine but the pad would stop rotating very easy under the 5 speed setting. Didn’t go much higher than 5 and a half on the speed and got the job done. Should I be using a smaller back plate and pad for better results? Less wear and tear on the PC? I want to order some more pads with the Labor Day sale. Thanks Jack
