Burned through my MF pad?
So I was detailing my Mom's Jaguar XF with my 7424XP, 5" MF cutting pad, and Meg D300. I take a lunch break half way into the job. I come back and begin again, when all of a sudden the pad flies off and this is the result. No, it's not a red velvet cake. It's my pad! Did I do something wrong? Should I have removed the pad before going to lunch? I also noticed some separation occuring in my backing plate. Is this common? I've only used the thing maybe half a dozen times. Thanks for the input.
Re: Burned through my MF pad?
I think u used too much pressure on the head of the polisher....
Looks like excess heat from too high of speed and/or excess pressure. Call Meguiar's and they'll replace it.
I went through that when I started using the mc pads.you have change them out more often.I use at least 5 pads on an average size car.to much pressure can overheat the pad...
Cianfrocca's Auto Detailing LLC
I don't think you need to use that many pads. I've been using 1-2 pads to do full cars since Dec '10 and I've never had a pad blow out on me like that. I'm using speed 4 on the GG6 with heavy pressure. I clean the pad after each section with compressed air, which I feel helps keep the temps down too.
Monitor the pad temps and if you feel it's getting hot then switch to a new pad. Excess product usage is also a contributing factor to pad failure.
Looks like too much pressure,product and lack of cleaning through-out the process.
Heres a little tip,I use 2 mf pads and alternate between them,example: start with 1 pad do one section,blow out pad with compressed air, switch pads and repeat( this allows pad #1 to cool while using #2 and repeat through-out correction procces.
If your using a da polisher applying the compound or polish to outer most rim of the pads helps a lot.
let the machine do the work not your arms......sometimes you have to apply a little more pressure, but with the MF pads 9 out 10 times the weight of the machine is enough to do what your trying to accomplish.
Hope this helps.
Same thing happened to me, Megs replaced the pads and backing plate once I sent them the pictures of the damage.
Chad is spot on as always!
By carlg in forum Auto Detailing 101
Last Post: 10-04-2020, 08:13 PM
By VETLAG72 in forum Auto Detailing 101
Last Post: 09-09-2017, 07:16 PM
By mrbrons in forum Wet-Sanding, Cutting & Buffing
Last Post: 07-01-2013, 03:45 PM
By darkangelism in forum Wet-Sanding, Cutting & Buffing
Last Post: 09-24-2012, 10:13 AM
By SATracker in forum Ask your detailing questions!
Last Post: 03-03-2011, 07:27 PM
