Page 6 of 6 FirstFirst 123456
Results 51 to 58 of 58
  1. #51
    Jun 2011
    2,711
    Re: Those who have the most RECENT G110v2, question for ya...
    Quote Originally Posted by Shiny Lil Detlr View Post
    ...Your Dynabrade will react just fine to 6.5" Meguiar's foam pads. Just swap out the backing plate and install your smaller one on it.
    Thanks Charlie!
    Guess I'll get to try out both today then. Meg's should be here in an hour or so. Can't wait....
    Bill
  2. #52
    Apr 2009
    176
    Quote Originally Posted by dougaross View Post
    Rupes LHR 21E Random orbital polisher sounds good. I wonder about quality?
    The Rupes LHR 21E (likely over $500.00 retail) is the next big thing. A dozen or more of us visited the booth at SEMA, and this machine is an engineering marvel that seems to have a promising future.
    It features the largest stroke of any random orbital available today, is balanced beyond anything in the category (accurate balancing it is a requirement considering the 21mm, or roughly 13/16" stroke), and took over two years to develop.
    Another super tool offered by Rupes is the air-powered LHR-75 BIGFOOT Mini Random Orbital Polisher ($397.00 retail).
    It features a 15mm diameter orbit!!!!
    Even their traditional-design Skorpio palm sanders are available in a wide array of strokes ($354.00 retail for the 12mm non-vacuum model).
  3. #53
    Super Member dad07's Avatar
    Nov 2010
    Charlotte N.C.
    4,227
    Quote Originally Posted by Kevin Brown View Post
    Now those air tools have my Undivided Attention!
    Tim
    "I have done so much with so little for so long.
    Now I can do anything with nothing"
  4. #54
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Well, if it's got Kevin Brown's endorsement, I guess this means I'll have another machine to add to my arsenal once they come Stateside.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  5. #55
    Aug 2010
    264
    Any idea when they'll be available? I want one already.
  6. #56
    Super Member VISITOR's Avatar
    May 2007
    9,728
    kevin.. when you have more time to play with one, please share your thoughts on it. i'm curious how different it will be compared to the flex 3401...
    p.s. thanks for your contributions to the all the forums, it's greatly appreciated...
  7. #57
    Apr 2009
    176
    Quote Originally Posted by BigAl3 View Post
    You are most welcome!
    Well,I only had limited time with it at SEMA, but I can assure you that it is nothing like the Flex XC 3401VRG.
    First off, the Rupes stroke diameter is massive, (8mm for the Flex, 21mm for the Rupes). The Rupes doesn't steer the pad when it encounters curves or machine tilt, since it is random orbit (nothing really new there).
    RPM/OPM ratings are nearly the same (4,800 actual for the Flex, although Flex rates it at 9,600, whereas the Rupes lists 4,200 RPM.
    It's easier to compare the Rupes to another random orbital.
    The engineer spent a lot of time balancing the machine. It is sensitive, so much so that a difference of 5 grams (.18 ounce) is noticeable! Whether or not this is a good thing... we shall see. The thing is, even with a heavier pad (we compared two identical pads, except one had been used awhile, so it had some buffing liquid absorption into the pad), the machine is smooth, and we were using it at 4,200 RPM.
    I'm looking forward to trying the machine out with the DA Microfiber Discs and Surbuf pads. Rupes does make their own specialized backing plates, so perhaps I can find one that'll allow me to exchange the current one for one that will account for the lighter DA Microfiber Discs (at least I am guessing they are lighter). Even if they don't make one, I can drill some holes into the supplied plate to either lighten or add weight to it (via buttonhead countersunk bolts, and washers if needed).
    The Rupes guys have put a lot of effort into slowing random rotation down, in hopes of avoiding too much rotation. Their philosophy is that if the backing rotates too quickly, the chance that edge digging of the disc or pad could occur, leaving a less than perfect finish.
    While I have been a big fan of the most rotation possible, I can see their point. Still, I'd much rather deal with too much rotation as opposed to not enough. To slow rotation, one seemingly simple way they've done this is to allow a rubber shroud to rub against the backside of the backing plate (the Skorpio Palm Sander also is built this way). The friction helps slow the rotation. I'll have to get a couple extra shrouds, so I can cut one to allow for no rubbing! The design also maximizes vacuum capability on machines designed for dust collection. That being said, I prefer very little rotation for slow speed final polishing, and have been known to drag my finger against the pad or plate to control rotation.
    The benefits of a large orbit are numerous. For one thing, more centripetal force is created as the backing plate orbits, so the backing plate will rotate more than a similar machine featuring a smaller stroke diameter.
    Next, for every rotation of the driveshaft (or every RPM/OPM), the entire pad and backing plate travels at a higher rate of speed since it is traveling more distance than a machine featuring a smaller stroke.
    I could go on and on about machine stroke... OH WAIT!
    I already have!: Machine Stroke - How It Affects Sanding and Polishing Performance
  8. #58
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Dang. I'm glad I held out buying a 3401. When is the release date again?
    Oh yea. Hey Kevin. Whats up Superfly?
  1. G110v2...2 for 2
    By DaveT435 in forum Off-Topic
    Last Post: 01-03-2015, 01:00 AM
  2. Product Question: Universal Dispenser Pump - Recent Orders Only
    By BlueBeast14GT in forum Product Reviews
    Last Post: 04-18-2014, 01:12 PM
  3. A different G110v2 problem?
    By BryanH in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 01-07-2014, 07:23 PM
  4. Should I buy a G110v2?
    Last Post: 06-26-2011, 03:08 AM
  5. First job with my G110v2. Tell me what you think
    By Brennan Beasley in forum Show N' Shine
    Last Post: 03-06-2010, 11:13 PM
