Meg DA using LC 5' plate + MF DA cutting and finishing pad 5"
Hi Folks
Is there a different in Meg MF DA 5" back plate and LC 5" backing plate.
sound a little silly but use want to make sure the LC 5" goes will with the Meg MF pads and work efficently with the MF DA system compound and finish wax.
Re: Meg DA using LC 5' plate + MF DA cutting and finishing pad 5"
Originally Posted by terentius
Hi Folks
Meg 5" DA back plate has a special small loop while LC has standard. You could possibly create extra unwanted heat using wrong back plate.
I agree with Mark....stick with what the manufacturer suggests for the backing plate. Its designed specifially for the system. Search the forum on excessive heat and pads and see what you find.
Alex ...."Do the right thing...even when no one is looking"
