Results 11 to 20 of 23
    Oct 2006
    Quote Originally Posted by Whitethunder46
    I have XMT pad cleaner on order. So I guess I can just spray it on and then rinse off with warm water?
    The only thing I don't like about the pad cleaning idea, is that then you have to let them dry to use again. Even after spinning them on speed 6, and even standing on them with in a towel, how dry are they? Don't they need to be completey dry in order to use again?
    if you stand on them and run the pc on 6 they are definatly good enough to use again. Might be a little moist but definatly not bad
    Super Member Mike T's Avatar
    Mar 2006
    Naples, Fl
    1,716
    Quote Originally Posted by 03gtmustang
    Dawn.
    Thats what I used before I got the XMT kit.
  3. #13
    Junior Member INMY01TA's Avatar
    May 2006
    Crofton Md.
    72
    The snappy clean works pretty good.
  4. #14
    Super Member sparkie's Avatar
    Aug 2006
    Gaffney SC
    5,357
    XMT Pad Cleaner. Green pad I sprayed 1/2 with XMT pad cleaner and rinse.
  5. #15
    Nov 2006
    Wow, impressive. The spray works that good?
  6. #16
    Nov 2006
    Brooklyn, New York
    35
    Would the Meg's Detailer Line All Purpose Cleaner work?
    Kin
  7. #17
    Super Member supercharged's Avatar
    Mar 2006
    7,305
    Quote Originally Posted by Gottabekin
    It will work, just be sure to dillute it with water properly. I would try something like 1(cleaner):20(water), see if that works. If not you can make it stronger. I would not make it any stronger then 1:10.
    And by the way, I personally prefer APC+, because it doesn't foam up like APC does, so it will be easier to work with.
    Good luck.
  8. #18
    Nov 2006
    Where do you buy APC+?
    Thanks.
  9. #19
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    I love the XMT spray, same results as Sparkie. Literally changes color back to normal as you spray. It replaced the DP Cleaning solution for good.
    Scott
  10. #20
    Dec 2006
    ive have good results with the wolfgang powder pad cleaner. does everything i need it to do and smells good to boot.
  1. Replies: 12
    Last Post: 06-17-2020, 12:20 PM
  2. I just need a "decent" foam gun
    By cfaas416 in forum Auto Detailing 101
    Last Post: 02-06-2018, 01:59 AM
  3. pH Neutral Wheel Cleaners as Tire Cleaners?
    By Setec Astronomy in forum Auto Detailing 101
    Last Post: 05-14-2014, 08:06 AM
  4. Placed a decent order
    By brondondolon in forum How to make money detailing cars
    Last Post: 05-11-2014, 08:18 PM
  5. Is DG APC decent?
    By Bunky in forum Auto Detailing 101
    Last Post: 05-23-2008, 07:09 PM
