Re: OPM chart for PC-7424xp
Can anyone confirm this chart for a new pc?
I'd pay for a settings chart like this for a drillmaster rotary..
Sent from my PG86100 using Tapatalk 2
Hi..What about the HD polisher? Anyone have the opm settings like those above?
Have you tried asking them directly? They own the Autopia . org forum - there might be more people with experience using the HD polisher over there.
Thanks for taking the time to post this.
While the OPM's at the various settings on the dial are good to know, at the end of the day regardless of whether you "know" what the OPM's are for the different settings are or not, you're always going to put a PC on the 4-6 setting to do paint correction work.
It's important to maintain pad rotation when trying to remove defects, (trying to remove a little paint), in order to work effectively. Having a pad simply vibrate or jiggle has little effect on defect removal.
In most cases, if you're using a foam pad you'll be on the 6 setting. You might bump it down a little if you're using a MF pad and the Meguiar's D300 per Meguiar's recommendations of running their pads/compound at 4800 OPM to avoid overheating the MF pads but the pad must rotate during operation. (So mark your backing plates)
Check these out too...
I recommend everyone read this first article first - before you need to troubleshoot
DA Polisher Trouble Shooting Guide
Then check these out...
Video: Mark your backing plate to make it easy to see pad rotation
Factors that can cause a pad to stop rotating on a DA Polisher
Thanks. Will enquire over there.
And please post a follow-up with what you find out back in this thread.
Thank you!
Last Post: 09-20-2016, 01:39 PM
By PeterPistol in forum Auto Detailing 101
Last Post: 09-19-2015, 07:03 AM
By CaneCharger in forum Auto Detailing 101
Last Post: 03-19-2013, 06:57 PM
By Meghan in forum Product Charts and Graphs
Last Post: 08-27-2009, 10:41 AM
By joe.p in forum Auto Detailing 101
Last Post: 04-29-2006, 12:51 PM
