Re: Bought a DeWALT dual action sander/polisher! Help...
OMG!!! Finally found some really good news!!
Check this out -
I guess it should work!
Originally Posted by sohail99
While I was doing that test with 8" pad on the back of my hand, I applied quite a bit of pressure and the unit didn't seem to bog down!!
(will check it with the pads anyways!)
It's not bogging down you want to worry about it's pad rotation under pressure.
I tried it on with a big 8" pad and it did seem to stop rotating under pressure!!
I also saw a few videos of PC7424XP pad rotations and I feel that DW443's rotations are quite less!
I've dug up a few articles claiming that this can do a great polishing job
For example - http://www.autogeekonline.net/forum/...lt-443-ok.html
And these
I think it needs some oiling as its backing plate is no rotating as freely as it does in a PorterCable!
I cant wait for my pads to arrive so that I can get down to doing a test spot with it!
Hi Sohail !
Looking at the various links you've posted , i guess the DW 443 should do the job to a fairly acceptable extent !
Regarding the throw of 5mm, which would result in :
- Smaller orbit resulting in a jiggling motion - more vibration
- Larger orbit helps to cover more area faster
Above is my understanding, request Mike & other experts to share their view too
Another question for the experts, can it remove the deeper scratches too ?
Hey! Nice to see you here !
Check this out - http://www.autogeekonline.net/forum/...lt-443-ok.html
I'll be removing a sanding seal and doing the pressure test and free rotation test again!
To remove deeper scratches you will be more effective to work by hand than a DA Polisher like the Porter Cable, Meguiar's or Griot's Garage DA Polishers, here's why, I posted this in another thread yesterday...
http://www.autogeekonline.net/forum/...taminants.html
Ultimate Compound by hand is the best hand applied scratch remover at this time that I've tested. Here's how to use it...
How to use a hand applied abrasive polish or paint cleaner by hand
For deeper defects it more effective to remove them by hand because you can exert a lot of pressure to the affected area with a couple of fingers. With a polisher all the pressure is spread out over the entire face of the buffing pad.
RIDS - The Definition of RIDS and the story behind the term...
RIGHT ON!!!
I still have mine apart from when I took the pics in the MOL thread.
I will also leave out the white ring... to juice 'er up, so to speak.
Way to be creative !!
Last Post: 04-08-2018, 09:52 PM
By agarabaghi in forum Auto Detailing 101
Last Post: 07-12-2013, 02:15 PM
By JohnMcD348 in forum Ask your detailing questions!
Last Post: 07-01-2013, 09:06 PM
By sebastian12 in forum Auto Detailing 101
Last Post: 03-21-2011, 06:47 PM
