Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
  1. #41
    Super Member sullysdetailing's Avatar
    Mar 2009
    South Florida
    1,963
    Re: Burning Paint with PC 7424
    Quote Originally Posted by killrwheels@autogeek View Post
    I never seen damage like that from a random orbital buffer, the surrounding paint wrinkled like it was not even cured. Need a professional to chime in here ...
    That what I was thinking.
    It is nearly impossible to burn the paint with a DA.
    It looks like the bumper was repainted and it didn't cure right. So the heat that the DA produced caused the paint to lift.
    Shawn
    Sully's Detailling LLC - South Florida
    www.autogeek.net
  2. #42
    Super Member DLB's Avatar
    Jul 2009
    Ringgold, GA
    1,211
    I saw this same exact type of burn happen, only with a rotary. It is (like Dana has said) a burn. And that too was on a plastic bumper - factory paint, about 5 years old.
    DLB
  3. #43
    Apr 2008
    Oklahoma
    773
    looks like someone was using naval jelly on their pad?
  4. #44
    Mar 2013
    189
    I burn my paint slightly while working on my car outside in the strong heat, direct sunlight with a 7424 :/ lol. It's barely visible, i didn't burn it much, just slightly. I have no idea why i did it under the sun.
  5. #45
    Super Member ObsessiveAutoDetail's Avatar
    Nov 2008
    Lincoln Park, Michigan
    445
    Historic thread I know... But you do know that bumper covers and trim pieces on most modern cars are no longer painted but "coated" with a film that is a dead match for the paint color. Kind of like contact paper. The only way I know this is my older brother works for a supplier to the big 3 who makes bumper covers and trim pieces. Before these pieces leave, they're "coated" instead of painted. The OP's picture looks as if the coating has torn or ripped off.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    Josh Bachman
    Obsessive Auto & Marine Detail
    www.obsessiveautodetail.com
  6. #46
    Feb 2013
    Paint wasn't cured. imo.
    Walt
  7. #47
    Nov 2013
    282
    Bumping old thread, what about us that don't have an inside option to use their DA? Just use out of direct sunlight and practice normal DA technique?
  8. #48
    Mar 2009
    1,268
    Quote Originally Posted by BlackRam View Post
    Do it in the morning before the paint gets too hot. Also don't do it on a windy day, because that can throw dirt onto the car to get between the buffer and the paint and cause scratches.
    The reason people buff inside is because the car stays cooler even when it's a hot day, and it blocks wind to prevent dust from getting on the car.
  1. Strick Through vs Burning Paint - Difference?
    By RWC32 in forum Auto Detailing 101
    Last Post: 09-04-2017, 08:13 PM
  2. Surbuf pads and burning paint
    By NiSyam in forum Ask your detailing questions!
    Last Post: 06-30-2012, 04:57 AM
  3. Burning through paint? what is this?
    By rider9195 in forum Ask your detailing questions!
    Last Post: 07-04-2011, 08:38 PM
  4. Foam pads (Griots) not burning paint?
    By xxnonamexx in forum Wool & Foam Buffing Pads
    Last Post: 05-26-2011, 08:51 PM
  5. Burning Paint...and how to avoid it...
    By orngez in forum Auto Detailing 101
    Last Post: 04-12-2007, 09:46 PM
