How to do it right??? From Guatemala
Hi, thanks for all the advise that give me in my effort to make my car brand new...
Last try I made holograms, or little swirl marks from my swirl remover, well after a long search finally found 3M UltraFina SE, so need and advise please..
Should i proceed like this or please let me know..
1. Wash my car
2. With swirl remover and LC Orange Pad remove the swirls, that is almost gone.
In this step i have a problem, i put a little polish in the pad, then in speed 3 of PC spread it, finally speed 6 work it. The problem is that the product dry so fast, that i thing i should spray a little water to make 2 passes, but i'm not sure.
The other question is that should i work it until it make a high gloss, or when turn transparent, that turns really fast at speed 6, let it dry and remove with a MF.
3. i thinking to use the ultrafina to remove the holograms with a white pad or should i use a blue pad???
4. Again with the white pad use final glaze from 3m, here i have another question, i check in videos that i should work it until make a high gloss, but it seem to not dry never, should i keep working it until it dry, or i putting too much product????
5. Should i use polish after this steps, i think not. But let me know???
Thanks for your commentary in advance...
From Guatemala...
Re: How to do it right??? From Guatemala
If you are using ultrafina to eliminate buffer halograms. Put enough polish on the finishing pad to keep the entire area where you are buffing wet with a thin layer of polish. Then go over the area for 4 or more passes at between 1500 and 1800 rpm with a finishing pad. Wipe off the oily residue with a scratchless microfiber, then check the surface. If it looks good do the rest of the car repeating the steps above then apply the LSP.
Derrick
By LSpec in forum Introduce Yourself
Last Post: 06-29-2013, 06:51 AM
By weeecho in forum Introduce Yourself
Last Post: 02-02-2013, 06:59 PM
By Pumaeu in forum Introduce Yourself
Last Post: 01-18-2013, 11:43 AM
By GeO2110 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 02-27-2009, 11:06 AM
By GeO2110 in forum Introduce Yourself
Last Post: 12-19-2008, 09:30 AM
