Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Is it worth it?
    Apr 2017
    137
    Is it worth it?
    Is this machine worth it or get something different?
    Here's my scenario and I know it's not apples to apples but should be pretty close. I got a chance to try a friends HF dual action (yes I know, not a supporter and not as nice) but very close from what I read. I got a neighbors boat to play with. I was using a very crappy HF cutting pad (new) which fell apart real quick and 3m compound and finishing material (06044). When I first started, I thought it was working pretty nice for a POS but then half way through, noticed the pad wasn't spinning much at all. Reminded me of my orbital. Was I pushing it too much or are these not that great? I was thinking of buying the porter cable but I am having second thoughts now. I would mainly use it for polish and wax on a boat and then for everything for paint correction on my cars...I just wanted to see what it would do since it wasn't my boat, boat owner didn't even care what it looked like...was just going to dump in with now wax! I have a rotary for my boat, just wanted to see what it can do.
    Any help would be great!
    thanks in advance!!!
    Super Member VISITOR's Avatar
    May 2007
    9,730
    Re: Is it worth it?
    Quote Originally Posted by Whipped500 View Post
    if you're going to use it on boats and cars then the flex 3401 would be a good choice. it's gear driven (forced rotation) and will not stop spinning no matter how much pressure you put on it. it also can be equipped with a 4" backing plate that will allow you to use 4" pads, and the stock 5.5" backing plate that comes on the machine you can use 6.5" pads. there is also a 4 3/8 backing plate you can purchase as well in which you can use 5.5" pads too. if you're looking for a traditional pc-style DA then i would purchase the GG6 and buy the 3" HD backing plate & 5" vented backing plate which will allow you to use a variety of pads like the flex...
    Griots Garage 6 Inch Random Orbital Polisher FREE BONUS!
    Griots Garage 3 inch HD Backing Plate
    Griots Garage 5 Inch Vented Orbital Backing Plate
    also, you can use your rotary for your boat then on the cars use the HFDA (if money is an issue) with same size backing plates above and pick up some quality pads (3.5/5.5" BOSS or LC Thinpro)...
    Nov 2015
    Los Angeles, California
    13,765
    Re: Is it worth it?
    If you were using it with the HF pads then I think it's safe to assume you were running it with a 6" setup which only lessens its potential and gave you even less of a real impression of what the actual machine can do for you.
    In my opinion if your boat is currently in rough safe then you're better off knocking through the grunt work with your rotary 1st... But if it's in ok shape and you're just looking to maintain it every once in a while then that HF polisher can do the job, just make sure to buy a 5" backing plate and some quality pads.
    Apr 2015
    PGH, PA
    1,482
    Re: Is it worth it?
    repack the grease in the HF unit and then install a 5inch vented Griot Backingplate
    ditch the 3m compound and the HF pads
    look into LC purple wool or their hybrid blue wool for boats
    also check out Marine 31 for the boat.
    HF has more torque then the PC..if you still want to upgrade to another standard throw, GG6 is where its at
    but since you mentioned boats and will also do cars
    go Makita PO5000c
    and pickup Gyeon compound and polish and some LC thinpros for when doing car
    ..or if you dont mind giving up a lil smoothness, Buff N Shine Low pros...or LC HDO(has 3.5 pads too if you convert HF to 3in griot boss plate)
    LC = Lake Country
    Junior Member Salmonbum's Avatar
    Jun 2015
    Dyden\Ludington, MI - Steamboat, CO
    69
    Re: Is it worth it?
    The HF doesn't have the grunt to do any compounding on fibreglass. Stick with rotary. I have used the HF and a GG6 to apply wax on countless boats and it works just fine. For wax I will stick with 6" bp and black finishing pad. I can tear thru a 31" boat in no time.
    I am curious if the new Makita will have the backbone in forced rotation to tackle gelcoat correction.
    2017 BMW M2 - 2017 Ram Laramie - 2016 Subaru Outback - 2015 Ram Outdoorsman
    2006 VW Jetta TDI - 2003 Duramax Diesel - 1999 Jeep Cherokee
    Apr 2017
    137
    Re: Is it worth it?
    I was just trying the HF to see what it could do. It was basically given to me. I was told just to hold on to it and that if they need it back, they know where to find it. I like to have my own stuff and that is why I was asking because I was thinking about buying the PC. I guess for as little as I am going to use it on the cars (again, have the rotary for the boat, just wanted to see what the DA can do) I should just take the freebie.
    With that said, I had bought the DA deluxe foam pad kit for it. It is the ccs pads and a 5" backing plate. Is this a good kit for the cars? I hope I don't need to exchange/ return. I didn't use these pads on the boat because I didn't want to wreck any of the pads on this boat that I was just playing with. These pads were bought to be used on my cars.
    Apr 2017
    137
    Re: Is it worth it?
    Any opinions on if the deluxe foam pad kit was the right choice for a newbie that is playing around when time permits? It has the 5" backing plate with the 6.5" ccs pads.
    May 2007
    9,730
    Re: Is it worth it?
    if you're going to use a 5" DA backing plate you'll want to use 5.5" (thin) pads to get the most out of the polisher and maximize rotation...
    Apr 2017
    137
    Re: Is it worth it?
    That's not good. I was hoping to not have to return/exchange that kit. I figured it might not be the best but it would be good enough for playing around with. I guess in all reality I didn't need everything that came. I just need the smaller backing plate and a compound, polish and wax pad. I'll have to call tomorrow when I have time and see if I can exchange?
  10. #10
    May 2007
    9,730
    Re: Is it worth it?
    that's why i'm not a fan of kits unless you plan on using everything in it. it's best to pick and choose exactly what you will use so nothing goes to waste...
  1. Opinions on clear bras. Worth it or not worth it?
    By AliMusa in forum Auto Detailing 101
    Last Post: 05-17-2013, 12:08 PM
  2. Is it really worth it?
    By Newdetailer1 in forum Auto Detailing 101
    Last Post: 02-29-2012, 05:55 PM
  3. How much would this be worth??
    By PlatinumRefl. in forum How to make money detailing cars
    Last Post: 10-24-2011, 09:10 AM
  4. every now and then...it's all worth it!
    By cooksnj in forum Off-Topic
    Last Post: 07-15-2011, 09:04 AM
  5. How much is my car worth?
    By Pontman43 in forum Show N' Shine
    Last Post: 03-26-2006, 01:17 AM
