Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Hybrid View
  1. #1
    Junior Member NLS8520's Avatar
    Join Date
    Mar 2013
    Posts
    83
    Post Thanks / Like
    Counterweight question when running 3" pads
    My PC7424 XP as a 5" counterweight as stock, when running these smaller pads say in my case a 3" pad do you just keep the 5" counterweight as is? I plan to run the 3 inch pad and backing plate from Lake Country.
  2. #2
    Super Member Eldorado2k's Avatar
    Join Date
    Nov 2015
    Location
    Los Angeles, California
    Posts
    13,835
    Post Thanks / Like
    Re: Counterweight question when running 3" pads
    I use my HF DA that way [using the 3" LC BP & pads] and it's absolutely no problem. You'll be fine.
  3. #3
    Super Member Mantilgh's Avatar
    Join Date
    Dec 2014
    Location
    Boonsboro, Md
    Posts
    2,724
    Post Thanks / Like
    I just asked Mike about a similar thing in this thread.
    http://www.autogeekonline.net/forum/...ing-plate.html
    This plate is designed and balanced for the GG6 which comes with 6" backing plate.
    I don't know if LC took downsizing into consideration when they designed their backing plate.
    ____________
    "The more answers I seek, the more questions I find."
  4. #4
    Join Date
    Mar 2013
    Posts
    83
    Post Thanks / Like
    Quote Originally Posted by Mantilgh View Post
    Thanks for the reply would be interested to find out if LC took the downsizing into consideration agreed.
  5. #5
    Join Date
    Nov 2015
    Location
    Posts
    13,835
    Post Thanks / Like
    Quote Originally Posted by NLS8520 View Post
    It's a pretty bare bones backing plate.
  6. #6
    Super Member Calendyr's Avatar
    Join Date
    Jun 2013
    Location
    Montreal, Quebec
    Posts
    3,996
    Post Thanks / Like
    I did transition my PC 7424 XP to a 3 inch pad (so I guess the backing plate is a tad smaller. It works well but there is a lot of fibration now. I did a quick scan of the AG store and a general search on Google but came out empty with counterweights smaller than 5 inch for the PC. Does anyone know if these exist, and if so where to get them?
    It probably won't cause any problem running this config as is, but I would really like to cut the vibration down.
    If a counterweight for 3 inch backing plates was available for Meguiars G110V2 polishers, I could switch them around too.
    I am wondering if the counterweight for the 3 inch Griot's Garage mini polisher could be used on other machines...?
  7. #7
    Super Member PaulMys's Avatar
    Join Date
    Jan 2014
    Location
    Eastern L.I. NY
    Posts
    10,772
    Post Thanks / Like
    I converted my PC to a 3" as well. As Calendyr says, the vibration increases a bit, but nothing that bad IMO.
    Also, I rarely run the 3" pads past speed 4-4 1/2. But that's just me.
    I also run the LC 3" plate with Griot's 3" pads. (Regular and BOSS).
    It is no coincidence that man's best friend cannot talk.
  8. #8
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    •If memory serves me correctly:
    -The PorterCable’s counterweight “sizes”
    mainly becomes a factor when using the
    DA as a sander.
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  9. Likes dlc95 liked this post
  10. #9
    Join Date
    Dec 2014
    Location
    Boonsboro, Md
    Posts
    2,724
    Post Thanks / Like
    I forgot I took these pictures till I read this thread.
    For comparison
    LC 3.5” orbital 2.6oz
    BOSS 3” 3.2oz
    HF 6” 5.0oz
    ____________
  11. Likes PaulMys liked this post
  12. #10
    Super Member
    Join Date
    Apr 2016
    Location
    Toronto, Canada
    Posts
    307
    Post Thanks / Like
    I use a 3" LC backing plate, and 3" LC Flat Pads on my 7424XP, and there's no noticeable increase in vibration or anything over the 5" BP and pads.
Similar Threads
  1. Smaller pads, ditch the counterweight?
    By 05RLS2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-26-2011, 11:29 PM
  2. 6" counterweight on 5.5" pads
    By c5z06camaro in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-05-2011, 04:45 PM
  3. 5" counterweight
    By IOMCAMARO in forum Auto Detailing 101
    Last Post: 11-21-2010, 10:21 PM
  4. Installing 6" Counterweight?
    By e24mpwr in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-30-2010, 09:04 PM
  5. Using counterweight with PC and Edge Pads
    By darksparkz in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 03-10-2007, 02:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» June 2024
S M T W T F S
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
