Results 11 to 20 of 26
    Junior Member trojanone1's Avatar
    Feb 2016
    Sioux Falls, SD
    38
    Re: 2nd time using my new PC
    Quote Originally Posted by Farmingdales Finest View Post
    I like you are new to detailing but with what I know you would probably be better off using a pad that has some more cut. The white LC pad is a pad most people would use to put on a LSP and with the chemicals you are using would only take minor swirling off.
    Here is my second ever detail a 2014 Ram that had some scratches that I didn't expect Meguiar's Ultimate Polish to work so well The only difference from you is I used a LC orange pad.
    Before UP
    After UP
    As you can see a huge difference Not perfect but I didn't think I would have been able to correct that much scratch without at least a compound and probably some wet sanding.
    Good luck in your search for what's best for you.
    I'd say that looks pretty good. How did detailing the 2014 Ram go in general? How hard is the paint compared to GM? My next vehicle is my personal 2014 Ram 1500 in red.
    Mar 2016
    The Jersey Shore
    80
    Quote Originally Posted by trojanone1 View Post
    Overall it went well. I should have used more pads. I used only 2 for the whole truck. You can see my thread about it under my history. It's the thread that says 2014 Ram QC.
    I can't compare the hardness against a GM as I have only done my wife's Hyundai Tuscan and my Ram.
    Good luck with yours. Since I detailed my truck I have bought ultimate compound and plan on doing a correction in the fall to prep the truck for hunting season and winter.
    2014 Ram 1500 4X4 Big Horn QC True Blue
  3. #13
    Super Member 4u2nvinmtl's Avatar
    Jun 2015
    Montreal, QC
    443
    To get a great correction out of my PC7424xp I use Meg's M101 or Menz FG400 to compound out scratches using cutting pads (I liked the Cyan LC Hydro-Tech pads). Then you'll need to follow up with a polishing pad and polish (I like CarPro Reflect or Menz SF4000 with a Tangerine LC Hydro-Tech pad)
    Tips:
    • You'll need ~5 of each pad (cutting and polishing)
    • Slow your arm speed to 1 inch per 1-2second
    • Mark the backing plate with a black marker line to see the pad spinning
    • Apply an enough pressure to where you hear the motor change tones but not so much that the pad stops spinning
    • Watch "Junkman" videos on YouTube, he's not in it to market products so he explains what a novice needs to know to get great results IMHO (he's still the only person I've seen walk on a hood and then compound out the scratches in one seamless video)
    • Try spraying a mist of water to extend the life of the product and increase cut
    • The washer is not optional
  4. #14
    Mar 2016
    The Jersey Shore
    80
    2014 Ram QC
    Here's the link to my Ram detail.
  5. #15
    Apr 2012
    7,494
    I busted out this Chevy 2500, Menzerna FG400 and LC Orange pads Rupes LHR15. It powered right through it. And as you can see it was heavily oxidized. I didn't find the paint hard by any means with that combination. I polished out the whole truck and lsp in about 7-1/2 hours.
    And crank that PC up to wide open!!!
    Swirl Free
    2019 Nissan Rogue SL
  6. #16
    Feb 2016
    Sioux Falls, SD
    38
    Quote Originally Posted by custmsprty View Post
    Swirl Free
    You mean go from 4 to a 5 or 6? I am definitely glad I joined this forum a couple months ago. I have learned a lot and hope to keep learning as I go.
    2014 Ram QC
    Damn your Ram cleaned up well! I bought my 14 used as well, but it looks flawless still. Pretty confident Griots AIO with white pad and topped with Collinite 845 12+ hours later will make it look even better.
  7. #17
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    WG 'Twins' with orange and white pads respectively is a nice combo for minor/average correction situations.
  8. #18
    Super Member spazzz's Avatar
    Jan 2014
    Madison
    1,013
    I would grab some Ultimate Compound and bump it to 6 while you are waiting for the orange pads.
    You would want to go over it with Ultimate polish to refine it.
  9. #19
    Apr 2012
    7,494
    Quote Originally Posted by spazzz View Post
    Or you could use FG400 and get both steps done in one step and be enjoying a beer a lot sooner than later
  10. #20
    Feb 2016
    Sioux Falls, SD
    38
    I do not have any compound in my stock so I will have to pick some up. Random question, are you over at the Grand Prix Forums? Your user name is familiar.
  1. Replies: 9
    Last Post: 04-13-2017, 12:37 PM
  2. Second Time Around! - Season 1 Repeats STARTING this Friday night at 7:30pm Easter TIME
    By Mike Phillips in forum Competition Ready on Velocity Channel
    Last Post: 08-04-2016, 10:31 AM
  3. Long-time reader, first-time poster
    By BMWMSPT in forum Introduce Yourself
    Last Post: 01-05-2016, 03:04 PM
  4. Saturday morning shine time! Fuzion time!
    By jamesalanb in forum Auto Detailing 101
    Last Post: 10-25-2013, 10:40 PM
  5. First time, long time from Concord, North Carolina
    By maz5219 in forum Introduce Yourself
    Last Post: 05-23-2012, 07:08 AM
