Re: Black Label surface coating, what's going on here?
Originally Posted by EvolutionDetail
Subbed for the outcome of this.
I also purchased the Elite kit, because it seem like a very easy process, when compared to other "Coatings"
Also just to contribute my .2cent to the OP.
If i have to guess, i'd assume this Pinnacle coating is some sort of "Sealant that is on steroids." But it is much more liquify compare to traditional sealants?
Because for coatings like OC , CQ , 22ple. The coating will not be removed by simply wiping with a MF Towel. You'd have to polish it off.
PS: Does anyone know, if the Pinnacle Black Label Coating provides any level of scratch resistance?
It is very liquid, and very much smells of IPA when applying.
As to the scratch resistance, I'd say no. I ran my fingers across the hood tonight just to check the surface, see if it did indeed feel like there was still coating there based on all the descriptions that have been posted up here. Felt a bit of grit and sure enough, there are very fine scratches in those exact spots.
My fault, of course. I should know better than to touch the surface without QDing it after 2 days even if it's in the garage. I wasn't going to introduce moisture just yet knowing I've obviously got some curing issues going on here. The fact remains it scratched just as easily as if there were no coating there. I can always buff it down with the SF4500 and reapply the coating.
Or, perhaps there is no coating there. I'm going to wait quite a while before washing. It's been over 48 hours now since first application, and I definitely applied liberally. The high spots I wiped out 16hrs later attested to that. I certainly hope I didn't take all the coating off when I rubbed out the high spots.
I just want to apply something that will make the upkeep of my car much easier and still look good. With a little kid barely over a year old running around all over the place, I don't have the time to spend 3 hours each weekend washing, waxing, and cleaning the interior. Got to wash it, dry it, and be done. I used the last couple of days of vacation to prep the car for max looks and the plan was to use the coating to lock it in after I got it there.
Now my question is, are there ANY paint cleanser or nano polish can be used without damaging trims / plastics? Because i HATE taping lol
2 things,
I have noticed that a fresh dressing or sealant on the trim makes a minor buffer slip clean up much easier.
Also, a strong dilution of IPA takes the polish right off the trim with just a little elbow grease. It makes sense, if you can use it to take the polishing oils off paint, you can use it on trim to do the same. Just be aware it'll leave the trim bare as well.
Yea, I realize polishing once a month is crazy lol.
Back at that time, i was just getting started with Detailing.
And i purchased SO MUCH products that i want to try them all.
So i polished it once a month to just try all the different products.
But now i don't EVERR plan on doing that craziness.
nano polish?
Ok,
Today was the first day my car has been in full sun for the last 2 weeks.
I just had a MOG moment. It looks absolutely fantastic.
I don't know what to say about the black label surface coating yet, but I know as most here do that the prep was the key. On black, the Menzerna SF4500 step was worth the extra 6 hours. So worth it.
No pics, sorry. It's cold guys, real cold today. 16 degrees and negative wind chill ain't how we roll in Texas. Maybe I can snag a garage shot, but it doesn't do the car justice like the sun does.
PBL is finicky with temps, at least that's been my experience. Of course I applied when temps was right at 60. I did miss a couple of spots and was able to buff out with mf towel and some work. I applied paint coating to mine and a friends mustang. There's probably only a slight difference between surface and paint coating. One thing for sure, after it cured for at least 16 hours on each car, the surface was super slick. As for scratch resistant, that's a negative! I found out a cat was chillin on my hood, footprints left at the scene, then decided to move and it definitely lost its footing resulting in a scratch on the hood...
That's a beautiful ride man! Love the lines on the challenger, can't wait to see what the cuds looks like...
The car looks great.
I think what is going on here is the coating will bond to the paint to a certain extent. But, the chemist designed it to be easy at PBMG, so I think you are able to remove the high spots much much later.
It would be like if you left the lid off a gallon of paint and came back 12 hrs later. The gallon of paint wouldn't be "dry", it's like one big high spot. However, if you paint it thinly on the wall - the wall would be dry. Not a perfect analogy, but that is how I think of it.
Thanks for the complements, guys. I appreciate it.
I hope like heck they make the 'Cuda with that 6.2L hellcat that's been rumored before the CAFE laws tighten up in 2015.
The coating thing is fine with me if they made it that user friendly, my concern is that I might have rubbed it off trying to level it. I hope it's a case more like a wax or sealant, where when you put it on there's usually an excess that you remove and everything looks much better.
Time and moisture will tell for sure.
By waterman in forum Auto Detailing 101
Last Post: 09-12-2019, 06:51 PM
By clnimck in forum Pinnacle Wax
Last Post: 12-13-2014, 10:45 PM
By Tector in forum Auto Detailing 101
Last Post: 08-03-2014, 06:01 AM
By rob_v in forum Auto Detailing 101
Last Post: 11-08-2013, 04:09 PM
Last Post: 11-03-2013, 06:34 AM
