Jacking up challenger
My bendpak quick jack doesn't reach the jacking points. I lifted the accord along the pinch weld. I can't do that with the challenger. The length of the jack is 45inches. I need about 60 inches i think. Someone suggested laying a 2x8 along the top of the lift. You guys on here are alot smarter than i am. Do you think that would be safe or a really dumb idea
Re: Jacking up challenger
Call Bendpak and see what they suggest.
They said they're working on extensions. The guy suggested going in from the sides but that won't work either
Owner's manual has the jacking-points...
and the jack-stands' placement points.
Or, try here:
http://cdn.dealereprocess.com/cdn/se...challenger.pdf
(Page: 505)
are you saying its is 60 or so inches from behind the front wheel arch to in front of the back wheel arch?
Depending upon what your doing you can always use rams or go to like harbor freight and and or buy a low profile jack and jack stands thus find a solid point to jack from cause the suggested point is said to chip the paint i d k why though
Originally Posted by RaskyR1
Not sure there is much you can do unfortunately. I think a board going across would interfere with other components, that and I wouldn't want to risk dropping a car.
On the Hellcats I've done I used the lift points in the manual as the pinch welds were not an option.
Rear
Front
pinch weld
I was gonna go from the rear jacking point to the frame just right of the front jacking point. I have to get under the car and look at this better. This weekend I'll take some pics
The last picture you posted, I'm not sure what that is.
I would put the rubber blocks that come with the lift on top of the bendpak so the board wouldn't interfere
By Tico in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 05-13-2016, 06:37 PM
By Justin at Final Inspection in forum Show N' Shine
Last Post: 05-22-2015, 11:37 AM
By hoyt66 in forum Off-Topic
Last Post: 03-26-2015, 10:07 AM
By PA DETAILER in forum Off-Topic
Last Post: 05-27-2013, 07:44 PM
Last Post: 02-06-2012, 05:23 PM
