Show Your Jacked-Up Rigged Detailing Stuff
So, I came up with this idea and it may even help someone fix something. I'm a destroyer. I'm hard in everything. My stuff breaks. So, a lot of time I rig it up so I can still use it.
AirForce Blaster developed an air leak when it got a tiny dent. I think it fell. So, I got RTV and sealed up the whole thing air tight, including the "normal leaks" then I wrapped it all in electrical tape:
Hit the cord area too, as air leaks out of there. Also, knowing my luck, it would probably go bad eventually:
Looks bad, works good.
Here we have a classic. All of a sudden, the battery case cover wouldn't stay on my Brinkmann. Other than permanent Krazy Glueing it shut, it took me a whole 5 mins to come up with this one:
Then there is the foam pads that have de-laminated. I Krazy Glue the Velcro on and it seems to work fine. Don't worry, very careful not to get it on any area that touches paint:
Not so much a detailing tool, but I do use it to warm leather seats to dry CarPro Fabric & Leather. The cord to my Wagner heat gun has been burnt so many times I covered it in tape, then Krazy Glued the ends so it doesn't unravel.
Basically, I buy a lot of Krazy Glue. When it comes to KG, I find the cheap 4 tubes for 99 cents generic stuff works just as good as the stuff that's $3.99 a tube. Just an FYI
Re: Show Your Jacked-Up Rigged Detailing Stuff
:/ pics didn't come through..
I believe in becoming who I am (Translation: You learn everyday.)
<-Bubba
Came through on my end. Refresh?
<-Bubba
Nice fixes.
The only mods/fixes that I can remember off the top of my head are....
I fixed a 25ft extension cable to my blaster sidekick
Installed Velcro strips to my flex and pc power cords
A split washer for the flex blacking plate
Hi, Im Vin
Swivels now, and doesn't ever fall over...
Tadd, I like that. I keep mine on a cart.
My homemade two bucket dolly....
Used a moving dolly and a plastic tote lid along with two 5 gallon buckets cut to secure wash/rinse buckets to cart.
These holes drilled in the bottom allows any water to drain and prevents the buckets from creating a "vaccum" when taking them out of the cart.
By jdgamble in forum Auto Detailing 101
Last Post: 08-25-2019, 12:15 AM
Last Post: 12-05-2014, 05:04 PM
By Nappers in forum Off-Topic
Last Post: 02-07-2010, 08:36 PM
By Excessive Detail in forum Show N' Shine
Last Post: 08-27-2007, 10:28 AM
