Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Aug 2011
    913
    Least Aggressive M105/205???
    Hi, I know when you work on your paint, you are suppose to go from least aggresive to most. I see people using the M105/205 combo a lot but since 105 is more aggresive then 205, shouldn't I start with 205 first then work into 105? I read several threads before posting and people always start with 105 first...so I am a bit confused as I thought 105 was more aggresive.
    Is it ok to go for 205 into 105 and stop after 105? Or do I always need to 205 after 105? Can anyone explain? Thanks
    Super Member rider9195's Avatar
    Jun 2011
    Ulster County, NY
    3,227
    Re: Least Aggressive M105/205???
    First off, yes M105 is more aggressive than M205. Here is a link that might be helpful.. http://www.auto-geek.net/charts/wax-chart.pdf
    It is a good thing to use to least aggressive method first. Many people that jump to M105 already know that M205 won't give the results they are looking for. If you end up using M105 first, you should follow up with M205 to bring more gloss to the paint.
    Ryan 2006 Volvo S60 R
    Aug 2010
    New Jersey
    15,279
    Yeah, you are kind of mixing two topics together here. The first is, yes you use a progression of polish/pads from coarser to finer to remove defects and then refine the finish of the paint, in the same way that if you wanted to round off a 2x4 you would start with some really coarse paper and then progress to fine paper to get a really smooth finish at the end. This is a bit blurred by the SMAT abrasive in M105 which leaves a better finish than the typical old school compound.
    The "least agressive method first" is don't use a coarse polish (compound) if you just need a fine polish. Since M205 is a pretty fine polish, and since M105 finishes so well for a compound, in most cases people simply start with the 105, as was stated above.
    Super Member A4 1.8tqm's Avatar
    Apr 2009
    Edmonds, Wa.
    1,932
    The method of "starting with the least aggressive first and moving to more aggressive" is meant for the test spot, when you are first determining the condition of the paint and the products necessary to correct it.
    Start out with a finer polish, if the paint comes out great then you don't need a more aggressive polish/compound. That way you don't go compounding, therefore removing a lot of paint, when all you needed was a finishing polish. But, If that polish didn't "cut it" try a more aggressive one until you are able to remove all the defects. Unfortunately a more aggressive product may leave some marks of it's own behind, which must be removed with a finer polish.
    So, determine your method of attack, starting with the least aggressive. Then once you figure it out, you actually work the other way around. Working from the most aggressive and making your way down to the final, finishing polish to get that perfect gloss.
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    When you are assessing your paint to see what is the MAXIMUM correction you can get with the LEAST AGGRESSIVE combo, you are going up a continuum of different pads AND polishes. You would start with M205 and a med cut pad and see how that does. Next, try bumping the aggressiveness of the pad. Need more? Go to M105 with a medium pad and see how that does and so on...I know in my writeups, they're so damned long already, I don't go into what didn't work...only what did.
    Super Member Rei86's Avatar
    Apr 2011
    1,087
    It should also be addressed that after every pass with M205 you should do a wipe down. M205 has a bit of polishing oils that conceals and even fills in the swirls than actually getting the defects out.
    Hello my name is Sean
    Aug 2011
    913
    Wow, Thanks everyone for all your insightful post! I learned a lot, that's why I asked for all your professional opinions...
    It all makes so much more sense, I thought I had to M205 the whole car, then follow up with M105, then back to 205, when you just test spot the least aggresive and move on up, thanks so much its all adding up...Glad everyone on this forum is so smart!
    Aug 2011
    913
    Quote Originally Posted by Rei86 View Post
    Oh, thanks for your tip, no wonder I see people using Eraser/IPA Wipedown after M205...
    Wait so if M205 hides/fills swirls rather than cut them out...and if I Eraser/IPA after to see the "true results"...what do I do to actually cut them out instead of hiding/filling them?
    Apr 2011
    1,087
    Like the PM you sent me and the PM I sent you back.
    M205 is a SMAT product so it will get swirls/scratchs etc out. However I suggest doing a wipe down as the polishing oils in M205 can actually conceal some issues if you didn't do a wipe down to see the true finish.
    So yes M205 WILL work and get your swirls etc etc out but make sure to just do a wipe down to be truly sure. Also when you do a wipe down it'll leave a nice bare paint so your wax/sealant/coating will have a great bare paint to bond too.
  10. #10
    Junior Member offthahorseceo's Avatar
    May 2010
    76
    so you start with least aggressive pad and product (m205 and lc black)
    if that doesnt cut it do you upgrade the pad first or the product first?
    for example, i have m205, swirl x, scratch x, megs uc
    pads
    lc red lc green lc black lc white lc orange lc yellow
    so would i start with 205/black. if that didnt go where would i go next? m205/white or swirl x/black?
    and from there?
    thanks guys i hope to have alot of pics of before/during/after tomorrow. this will be my first real correction. up until now ive just been applying waxes sealants and glazes.
    my camera isnt fancy/powerful but it takes pretty good pics imo
  1. More aggressive pad? Or more aggressive compound?
    By tone357 in forum Auto Detailing 101
    Last Post: 12-28-2015, 10:17 PM
  2. Is M105 More Aggressive Than Ultimate Compound
    By rweekley in forum Auto Detailing 101
    Last Post: 09-02-2012, 09:05 PM
  3. Factors that affect how aggressive or non-aggressive a product is...
    Last Post: 06-16-2011, 03:40 PM
  4. Infamous M105/M205 combo; why do I need M105?
    By flaco in forum Ask your detailing questions!
    Last Post: 08-17-2010, 01:44 PM
  5. What's the difference between OLD M105 and the new formula M105 and...
    By O.C.Detailing in forum Ask your detailing questions!
    Last Post: 10-07-2009, 10:44 AM
