Michael, getting to a one step correction with a rotary and flawless results will be quite challenging but not impossible.
I would equip the PE14 with the 5" flex foam bp pictured and a polishing pad such as the green B&S and SPF, Menzerna PF2500, or another high quality DAT based product.
Technique is really going to be key and working surgically clean as equally important. You will want to ease up on pressure much sooner than normal and use just the weight of the machine for the last 2-3 passes.
I forgot to add to cut your speed back to 600 for the last 1-2 passes with less than the weight of the machine to finish out with. I other words I would pull up just a tad on the machine to finish out with.
Also, hot some 2000 and 3000 grit sandpaper, tire coating brush applicators, and some Wolf's jeweling polish... Figured I'd give it a try. I have Menzerna 4000, but couldn't rationalize buying 32oz of 4500.
Perfection is attained by slow degrees; it requires the hand of time. (Voltaire) 2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
Post up your thoughts on the wolfs polish. Was interested in that one.
