Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Oil Change Pump
    Super Member Reddwarf's Avatar
    Mar 2006
    Dallas, TX
    2,074
    Oil Change Pump
    Has anyone tried a device like this:
    http://www.pelaproducts.com/HowToUse1.htm
    One oild change would just about cover the cost, but I'm not sure if it really works or not. I saw an ad somewhere that said Mercedes Benz dealers use this or a similar device to change oil in customer's cars.
    _____________________________________
    "Dogs in cars again. Going away. Going away fast" - P.D. Eastman, Go, Dog. Go!
    Super Member dengood1's Avatar
    Jun 2006
    Central Florida
    3,030
    Quote Originally Posted by Reddwarf
    Hmmm......I might have to look into this one as changing oil is always a messy task. If you get one let us know how it works!
    Super Member Gary Sword's Avatar
    Nov 2006
    Southwest Florida
    4,168
    I have never seen anyone change the oil like that. I always change the oil in my cars myself. To me it's not a problem to unscrew the plug on the oil pan. On my Lambo there are 2 plugs, one on the oil sump and one on the engine. It takes 10 liters of oil. I wonder if you can even get all the old oil out using that method.
    Super Member pt91's Avatar
    Mar 2006
    AR
    518
    I have been using this MityVac version for the past year without problems. Well there was the one time the tube came off and made a bit of a mess on the floor but no big deal.
    The first time I used it I crawled under and removed the drain plug after I removed all I could with the pump. Not one drop came out. I also measured the amount I removed and it was more than is posted online for the usual recommended oil fill amount.
    It is just a little faster and cleaner than the old fashion way on my cars.
    Nov 2006
    Southwest Florida
    4,168
    Quote Originally Posted by pt91
    Thats interesting although it would not work on a car with a seperate oil sump. The dip stick is on the sump and there is an oil pump that pumps the oil to the engine. It would work getting the oil out of the sump but not the remaining oil in the engine.
    Mar 2006
    AR
    518
    Quote Originally Posted by Gary Sword
    It also doesn't work on some model vehicles. I can't remember the list exactly but a few Fords and some others.
    Mar 2006
    Dallas, TX
    2,074
    I saw an ad for one that listed cars it doesn't work on and they specifically cited Porche becuase they use a sump pump. So I would think it would not work on the Lambo either. You car holds 10 liters?! That's a bunch. Do you use synthetic? My Jag manual says to use synthetic only and to change every 10K or year whichever is first.
    PT91: Thanks for the tip. I'm glad to hear that it works. Your model looks like it has two lines coming out of it. Is one for pumping out the oil into a container?
    Mar 2006
    AR
    518
    PT91: Thanks for the tip. I'm glad to hear that it works. Your model looks like it has two lines coming out of it. Is one for pumping out the oil into a container?[/QUOTE]
    Probably. You can reverse the flow to add a fluid but I have never used that function.
    There is also an air driven version of this model that might be worth looking at. I think both can accept a brake bleeding kit which I might try out in the Spring.
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    Boat engines have used this method for decades so it must work well. I prefer the "crawl under and get dirty" method but both do the job.
    Rick....now in North Texas
  10. #10
    Dec 2006
    135
    Hum, don't some cars have magnetic tips on their drain plugs? I would think you would be forgoing the opportunity to check your plug for metal debris and such by doing this.
    Of course, it isn't much of a problem in modern engines, but its better to check such things anyway.
  1. How to use SHURflo pump?
    By mikehookipa in forum Auto Detailing 101
    Last Post: 01-16-2018, 12:26 PM
  2. on-demand pump?
    By jgibson2980 in forum How to make money detailing cars
    Last Post: 12-03-2014, 08:06 PM
  3. to pump or not?
    By shop1detail in forum Auto Detailing 101
    Last Post: 07-24-2014, 06:01 PM
  4. What do you use in your pump sprayer
    By dsg03gt in forum Auto Detailing 101
    Last Post: 02-28-2013, 10:37 AM
  5. Water Pump?!?!?
    By ALLN1WASH in forum Auto Detailing 101
    Last Post: 02-20-2011, 09:57 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
