Re: Mike Phillips and Yancy part of 3D Car Care
Mike has suggested in the past that he tops some aoi's with polymer net shield.
I have used that technique to great affect.
Isn't can coat very similar?
Originally Posted by
Stlchucky
No, unless you are using it to top a ceramic coating.
An exception might be something like Dr. Beasley’s NSP Z1 which is essentially an AIO coating. I would not use Can Coat to top an AIO that uses some type of polymer sealant as the protection as it will not bond properly. If you did it will the Can Coat fall off? No! But you would not be getting the full benefit of the product.
Al Schmidt
"Adventure, is a car called Riviera..."
