Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
    Sep 2013
    S.E. Massachusetts
    312
    Question on tires air pressure gauge
    My air tire pressure seems to be unreliable. Inaccurate reading.
    Which tire pressure gauge is more reliable/accurate digital or analog?
    Which brand are reliable/accurate?
    Aug 2010
    New Jersey
    15,171
    Re: Question on tires air pressure gauge
    How do you know yours is inaccurate? Is it digital?
    I still use analog gages, I got a couple recently from that river store since my old ones the seals were dried out and it was pretty obvious I wasn't going to be able to get parts for them anymore.
  3. Thanks java thanked for this post
  4. #3
    Sep 2013
    S.E. Massachusetts
    312
    No, it's a dial gauge.
    This is one of the question I forgot to ask, how can I check if the gauge is inaccurate. I going by, I get a different reading when I check the tire pressure first thing in the morning. I'll will get 33 PSI one morning then the next I'll get 40 PSI and so on.
    Even though the gauge will read I have 35 PSI in the tires including the spare the dash TPMS warning light will come on. The dealer said there nothing wrong with with the car or TPMS system.
  5. #4
    Nov 2015
    Los Angeles, California
    13,765
    I believe they sell a digital gauge made by Craftsman that’s supposed to be the best 1. Look it up on youtube, they’ve got videos on it.
  6. Thanks java thanked for this post
  7. #5
    Aug 2010
    New Jersey
    15,171
    Quote Originally Posted by java View Post
    Ok, this is more complicated--temperature has a direct effect on pressure. So one morning could have been a different temperature (change is about 1 psi per 10°F), plus driving will heat up the tires. Also moisture content in the air in the tire can change that, too.
  8. #6
    Sep 2013
    S.E. Massachusetts
    312
    Does the TPMS plays a big role in how the tire pressure behaves on cold days?
    I check the tires pressure first thing in the morning before driving it. If I do drive it I make sure the tire pressure is at least 35 P?SI and cold without driving I make sure it's 32 PSI.
    The last time I put air in the tire it was -3 degrees according to the dash outdoor temperature gauge.
    On a SRT Durango I'm trying to get the dash tire pressure gauge to read the same as a tire air pressure gauge. It 's always off from 5 to 10 PSI from the dash to the tire gauge. It's enough to drive someone nuts.
    Is there a trick to get the PSI to have the same reading? Like driving a certain amount of mileage before checking tire pressure or tire have to be a certain temperature before checking.
  9. #7
    Sep 2013
    S.E. Massachusetts
    312
    Is it the Craftsman model number MS4376?
  10. #8
    Aug 2010
    New Jersey
    15,171
    No, it has nothing to do with it.
    This is your problem. The TPMS monitor runs off a battery, that has to last 5-10 years. The battery is activated by the motion of the wheel, otherwise it would be on all the time (even when you're not driving the car) and wouldn't last very long. If you check your TPMS without moving the car, it will be showing you the pressure reading from the last time you drove the car, when it was probably warmer than -3 and the tires were warm from driving.
    I would trust the TPMS system to do it's job. Or is the problem you're having is that you get a TPMS light and you're trying to find out which wheel is low? Mine has individual readings so I don't have that problem, but I understand a lot of vehicles don't.
  11. Thanks java thanked for this post
  12. #9
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,376
    Mine doesn’t I have to check each tire to see but most of the time when my light goes on all four need air.
  13. Thanks java thanked for this post
  14. #10
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    I often get a similar variation in the readings
    between the tire gauge and the TPMSs when
    I either do the exchanges from the Summer
    tire/wheel assemblies to the Winters (and vice
    versa); or from scheduled tire rotations.
    A few miles being driven down the road;
    hitting the “DISMISS” message in the DIC
    (until it finally goes away); or the OBDII;
    is the usual cure.
    Hope it isn’t that your TPMSs need replaced.
  15. Thanks java thanked for this post
  1. Paint thickness gauge question
    By runrun411 in forum Auto Detailing 101
    Last Post: 07-24-2014, 09:53 AM
  2. paint thickness gauge question
    By kirkatizer in forum Auto Detailing 101
    Last Post: 02-05-2014, 11:29 PM
  3. Question about coating thickness gauge????
    By Joelotto in forum Auto Detailing 101
    Last Post: 05-02-2013, 08:02 AM
  4. Tire pressure gauge caps
    By kaboose786 in forum Off-Topic
    Last Post: 09-17-2011, 08:14 PM
  5. Another Paint Thickness Gauge Question....
    By mcpp66 in forum Auto Detailing 101
    Last Post: 02-07-2010, 11:06 PM
