Re: Meg's Wheel Brightener, ratio questions
Originally Posted by
LEDetailing
No kidding on the sprayers. I swore I rinsed out my gray Tolco sprayer last time after using WB and the sprayer was still dead. I wonder if the vapors are enough to eat the seals?
I never use WB anymore unless wheels are caked with dust. Gets used on friends and family thrashed wheels. I switched to D143 on my own wheels and tires and never have to worry about all the WB issues. WB does work magic on wheels that haven’t been cleaned in months/years. Probably one of the easiest products to see an instant result from. That also scares me too.
No way are vapors alone eating seals, do as El recommends below and you'll be fine.
Eldorado2k
I’ve found a way to make it a bit less annoying. What I’ve done is taken an old sprayer that clunked out a while back and cut the straw off and close it shut. Then I keep a bottle filled with water and the sprayer I switch in to use when ready outside on the patio table.
Quik switch out, and when I’m done switch back and spray it clean with the pure water bottle and it’s all done outside + sprayer doesn’t get ruined.
This is what I do, in 5 years I've only used 2 sprayers. Only reason one went bad is I forgot to spray water through it, so it was my fault.
Steve
-The Titanic Was Built By Professionals But The Ark By Amateurs-
"Boanerges"
No "gray area" on this product
2022 Elantra N Cyber Gray
Klasse Act
Explain, further for those of us "slow " folk.
Steve
"Boanerges"
DogRescuer
Well I mean people either like it or they don't, it eats bottles or it doesn't, it's too strong to use everyday or it's ok, etc.
