same pressure washers different companies
Why are so many electric pressure washers identical example
1. Black Max 1,700 PSI Electric Pressure Washer with Surface Cleaner
2. Ryobi 1700-PSI 1.2-GPM Electric Pressure
3. 1700 PSI Pressure Washer ? Power Stroke
Yes a few gas models are very close as well
Reason: links removed : review forum rules under FAQ
Re: same pressure washers different companies
Is this a serious question?
They're all made by the same factory, the only difference is the color of the plastics, and the sticker they put on them.
yes sir, maybe someone knows that one company that makes but are sold and branded under some other company but may all have matching parts with different part numbers, I own a gas unit the pump may be the issue found different brand companies with same unit as my unit which is now discontinued, different part numbers on the pumps but the exact same pump from what I have been told of as of lately
thanks that was my exact thought @jcautin87
Reason: added text need and type error
So what are you saying, you have a gas pressure washer, the pump is bad, you can't buy the pump, so you are trying to find another brand that uses the same pump and maybe they still have the part available?
If that's the case I would have titled your thread something like "need pump for xxx brand pressure washer".
Pump issue taken care of, was just in the market for a back up pressure washer (electric) do to northeast winter will get and install new pump in spring 2017. have one electric unit (KARCHER) still functioning like to keep spare on hand, washing looking to run an electric unit without an external pump off (GRAVITY FEED) IBC TANK to do quick wash & dry service. figured I try an A.R unit and found one that has a triplex pump (longer lasting) AR Blue Clean 1,500-PSI 1.4 GPM Electric Cold Water-AR112S - The Home Depot
had research the three units from title of this thread because I have seen a few video or peolple using the same style unit from title.
1. https://www.youtube.com/watch?v=Zayb2N1sH00
2. https://www.youtube.com/watch?v=Nx49I71SoAc
Reason: added text
By 808_detail_nut in forum Auto Detailing 101
Last Post: 04-12-2014, 03:05 PM
By jimjc in forum Auto Detailing 101
Last Post: 06-10-2013, 05:06 PM
By DonMTV in forum Auto Detailing 101
Last Post: 12-31-2009, 08:51 PM
By M3Cosmos in forum Auto Detailing Tools and Accessories
Last Post: 01-20-2009, 11:33 AM
By FMINUS in forum Auto Detailing 101
Last Post: 05-10-2007, 09:47 PM
