Page 13 of 23 FirstFirst ... 345678910111213141516171819202122 ... LastLast
Results 121 to 130 of 221
  1. #121
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: Duragloss Enviroshield Ceramic Coating System
    Quote Originally Posted by Shortspark View Post
    Bob, I think 105 has some, but very little polishing agents.
    The 111 is suppose to be pure sealant.
    The real problem about your legitimate concern is that the bonding agent
    (601) that both of these are generally used with
    does have a stronger polishing agent that is capable of removing old wax.
    I may be wrong but I believe Duragloss #111 also has "polishing agents".
    However: Duragloss #601 does not list as having any such "polishing agents".
    Back to my original concern:
    Wouldn't the "polishing agents" in #105, #111, (and #601?) remove, at the very least:
    Some of this new Duragloss Coating? How could they not?
  2. #122
    Jun 2012
    671
    I don't really know what is in any of this stuff. All I know is what is contained in product descriptions. For example, here is what AutoGeek says about 601: "Duragloss PBA is completely transparent and undetectable underneath the sealant. It removes old wax, which can cause the final coat of protection to appear cloudy, and thereby enhances the final gloss". Because it says it removes old wax, I have to assume it is either a paint cleaner or maybe it is a true polish and contains abrasive agents of some kind. If it removes wax, no matter what chemical or abrasive process it uses to do so, I have to believe it would also be detrimental to a coating. But again, that is an assumption.
    As far as 111 is concerned, I again refer to AutoGeek's description: "Duragloss Clear Coat Polish (111) is what we would call a paint sealant. It actually has no abrasives in it and therefore does not fit what most modern car care specialists define as polishes".
    So, if we believe these product descriptions, it would appear the bonding agent would indeed impact adversely on the the coating (or anything else it is put on) and is intended to be used as sort of a cleaner in preparation for an application of sealant. Unlike most paint cleansers, it also assists in the bonding process, at least it does for Duragloss sealants and I would assume it should also assist any other poly-seal product.
    Conversely, (and here is yet another assumption from the description) it appears 111 by itself has nothing in it to adversely affect the coating. Having said that and assuming even if it is true, why would one want to put 111, or anything else for that matter, on top of a coating, which if I have read about this correctly, was developed to be a long lasting, stand alone LSP? As I said before, putting something on top of a coating seems to defeat the purpose.
  3. #123
    Dec 2010
    Ohio, USA
    21,057
    I agree with you...wholeheartedly...about not "topping/layering" a Coating with another different LSP!!
    No matter #111's product description...
    According to #111's MSDS:
    It has "polishing agents".
    Often these two forms of data are in conflict.
    But as previously proffered by Mike Phillips:
    (and I paraphrase)
    "It's not what's on the bottle's label...
    It's how the product performs!"
  4. #124
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Duragloss 111 is labeled a clear coat polish but it's really just a sealant and has no abrasives. This is sort of confusing considering its name..
    Duragloss 111 is a very nice product and leaves a beautiful long lasting shine behind and its durability can be increased by adding Duragloss 601..
  5. #125
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by BobbyG View Post
    Hi BobbyG...
    So are you saying it's best to disregard Duragloss' MSDS regarding #111?
  6. #126
    May 2012
    2,475
    Why are people coating their cars and then adding a sealant? Pointless IMO.
    If you want to "rub" on your car just use aquawax as a drying aid.
  7. #127
    Feb 2012
    Palatine Illinois, USA
    24,756
    Quote Originally Posted by KillaCam View Post
    Good point Killa and you know what, these coatings are going to make me re-think my whole way of doing things. Its looking like all I'll need after applying the coating from DG is do rinseless washes and apply AW, that's it. If that's the case, I need to sell off my LSP's, sounds like a fire sale is coming, LOL!
    Although a different coating I applied 2x's DPPC to my old CR-Z last November and we had a brutal winter like everyone else did in the midwest/northeast and the car cleaned up VERY easily and the shine was awesome! I never used a paint prep either but would encourage people to use it and I ofcoarse have the Squeaky Clean as well as DP paint prep to go along with the DPPC now.
    Once the DGPC is applied this Sunday I'll be reporting from time to time about looks and water beading/sheeting/etc, this is where having a single thread with everyone reporting their reuslts/impressions of this new coating from DG.
    2022 Elantra N Cyber Gray
  8. #128
    Regular Member 1kwikf's Avatar
    Jan 2014
    Illinois
    140
    just wanted to add that I placed my order for this coating today. I will be using it on a 2013 ford focus not bad for $38
  9. #129
    Feb 2012
    24,756
    Quote Originally Posted by 1kwikf View Post
    The price of this kit is unbelievable, then factor is FIVE DOLLARS for shipping, you've got nothing to lose and everything to gain!!
  10. #130
    Feb 2012
    24,756
    Lightbulb Re: Duragloss Enviroshield Ceramic Coating System
    Ok, just got another email from Bill and he said to just wash the car with their #901 wash but I live in an apartment and have to use rinseless, so I asked it that was ok to use, waiting on answer but I for one will continue to use their rinseless wash as I live in an apartment and even if I didnt', I'd have NO desire to go back to conventional methods. I should also pass along that he said for me to NOT even use AW on the car once its coated, very surprising info right there!
    What do you guys think about all of this?
  1. How do you apply Duragloss Enviroshield
    By conman1395 in forum Ask your detailing questions!
    Last Post: 10-12-2016, 05:47 PM
  2. Duragloss Ceramic Coating
    By jimjc in forum Auto Detailing 101
    Last Post: 01-07-2015, 09:14 AM
  3. Duragloss Enviroshield Questions
    By Setec Astronomy in forum Auto Detailing 101
    Last Post: 05-21-2014, 04:55 PM
  4. Duragloss Enviroshield Ceramic Coating System
    By VISITOR in forum New Car Care Products
    Last Post: 03-15-2014, 02:18 AM
