Results 1 to 9 of 9
    Jul 2012
    49
    Will 5.5" LC CCS Pads Fit on 5" Backing Plate
    The heading pretty much sums it up... I am looking to order some pads on here, specifically a six-pack of Lake Country CCS 5.5" Pads for my PC. There is a 5" backing plate, and I prefer to get some feedback from all of you on fitment before I spend $40 on pads which may be too small...
    Thanks in advance!!
    Christopher J Messier
    Topher's Detailing
    Detailing Rig: 2008 Mini Cooper Clubman S
    Aug 2010
    817
    Re: Will 5.5" LC CCS Pads Fit on 5" Backing Plate
    I dont use CCS pads, I have hydro techs but I run the 5.5" in pads on my 5" backing plate no problem. Actually they might even be 5.25" Im not sure.
    Yes.
    Click on the link below and I included high resolution pictures answering your questions.
    5" and 6" Backing Plates on 6.5" pads (Pictures to show safety margin)
    Here's 5" backing plates on 5.5" pads to show how they fit. Shown are the Meguiar's W67DA and the Edge DA 500 on 5.5" Hydro-Tech pads and 5.5" CCS pads
    5.5" CCS pads
    In the Gtechniq EXO video, I hold 5.5" pad and show Trista how to align and attach it to a 5" backing plate at some point in the video.
    Video & Pictures: 1965 Fastback Mustang - Gtechniq EXO Show Car Makeover!
    Remember to mark your backing plate... by the way, that's a 5.5" Hydro-Tech on a 5.5" backing plate in the picture below.
    Video: Mark your backing plate to make it easy to see pad rotation
    Here's a quick video that show how and why to mark your backing plate to see and monitor pad rotation while doing any correction or polishing steps.
    It's also important to maintain pad rotation with PC style tools when using a one-step cleaner/wax or AIO type product on neglected paint.
    It's not vital to maintain pad rotating when applying a finishing wax or finishing paint sealant to a finish that you've just buffed out.
    Aug 2010
    817
    Doh, Ive been putting that line on the side of the pads, backing plate makes much more sense.
    Super Member Buckskincolt's Avatar
    Aug 2009
    OR
    1,585
    The 5.5" pads are perfect for the 5" plate. Just a suggestion I'd opt for either the hydro tech pads or the flat pads instead of the CCS pads. I feel they finish better and absorb less product. First choice is HT and a close second is the Flat FWIW. the hydro tech pads are more $$$ but I feel they are worth it.
    Lake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads 3 Pack - Your Choice!
    Lake Country 5 1/2 x 7/8 inch Beveled Edge Pads 6 Pack, foam pad kit, build a kit, buffing pads, curved edge pads
    "Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
    Newport, Oregon USA!
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,185
    5.5" pads will be a perfect match for a 5" b/plate.
    Flex 3401 & PE14
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    I usually use a smaller bp than the pad.
  1. Replies: 19
    Last Post: 05-31-2020, 02:42 AM
  2. Need 3" backing plate and pads and an AIO
    By JMak97008 in forum Auto Detailing 101
    Last Post: 04-13-2018, 01:00 AM
  3. Any downside to using 3"/3.5" backing plate & pads on 6" DA
    By dennis hiip in forum Auto Detailing 101
    Last Post: 09-16-2014, 05:01 PM
  4. 5 inch backing plate - 6 1/2" pads or 5 1/2"
    By BFEHB in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 02-17-2014, 10:54 PM
  5. Using 6.5" pads with 5.0" backing plate
    By D_Nyholm in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 06-11-2009, 09:10 PM
