Page 8 of 8 FirstFirst 12345678
Results 71 to 76 of 76
  1. #71
    Super Member loudog2's Avatar
    Aug 2008
    St. Charles, IL.
    2,880
    Re: Gtechniq EXO - IN STOCK!
    Quote Originally Posted by Dragonfueled View Post
    I also noticed that it disappeared rite away. I wiped each panel after application but didnt see the need to cause like I said it seamed to just vanish. .
    I just finished putting 2 coat on my black Highlander. As far as vanishing, I noticed hazy streaks if not wiped down fully. I guess it was more noticable on black. So the question is, Do you wipe it down while still wet? I used a short pile edgeless polish removal towel for application and removal. It seemed better to use a softer short pile to buff instead of the ww/edgeless type. Application ws easy, it's like the fuzion of coatings. I will see tomorrow in the sun how it looks.
    Last question. Is EXO basically adhered to the paint upon evaporation? Will aditional final buffs affect the layer. I had to go back and buff off the streaks with a little elbow grease.
  2. #72
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Lou, you should knock it down right away. Good lighting is a must. Hope you didn't mar your black paint by rubbing too hard.
    Quote Originally Posted by loudog2 View Post
  3. #73
    Regular Member gtechrob's Avatar
    Sep 2010
    103
    for more application information see:
    [ame=http://www.youtube.com/watch?v=TQB0oRKDJ_Y&feature=player_embedded]Gtechniq EXO Demonstration - YouTube[/video]
    [ame=http://www.youtube.com/watch?v=qbmz25noz-o&feature=player_embedded]Gtechniq EXO Demonstration part II - YouTube[/video]
  4. #74
    Aug 2012
    New jersey
    [quote=Rsurfer;721379]Did your body shop guy say what he would use?
    On the back of the prep sol container it says removes grease and silicone but shouldn't be the last step before painting. I asked my body guy and he said its because it could possibly leave a film.
    yeah there's a product called final wipe. I looked into it and it's basically expensive rubbing alcohol. People that bought it said they would of just used there own ipa mix if they did it again. Again though i think you gotta use something stronger like the prep sol to dissolve and then ipa for a nice clean surface.
  5. #75
    Nov 2010
    1,337
    [quote=Dragonfueled;721448]
    I think IPA is a good idea then. I just dont like the fact that Carpro erasor is definitely leaving something behind on the paint. It leaves a slick, smooth finish, so something is there. But again, like I said, its VERY negligible because the coatings are using there own drying/curing agents which are likely going to clean off the paint somewhat while wiping on.
  6. #76
    Nov 2010
    1,337
    On the back of the prep sol container it says removes grease and silicone but shouldn't be the last step before painting. I asked my body guy and he said its because it could possibly leave a film. Carpro is an ipa and states on the bottle that it's for wiping down before using quartz product. I just figured it would remove any remnants of the prepsol and was designed to be used before a quartz product but not strong enough to be used as a stand alone solvent.
    I'll try the dark room method. That makes sense to me as you could catch the light on an angle instead of bright lights all over thanks for the tip.
    This may sound strange, but you actually want a weaker light when checking white paint. Nothing over 250 watt IME. When you step up to the dual 500watt (1K total) lights, you actually get a snow blinding effect on the paint. You kind of drown out the defects with so much reflection and lighting. If the room is dark I can actually spot defects very well with just the lighting of the garage door opener.
    The bottom line is that white kind of sucks to work on ! lol. I always seem to use more product when working on white compared to a black car..
  1. G15 not in stock
    By AV8R in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 01-06-2020, 08:49 AM
  2. Stock it up, with 25% off!
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 04-19-2018, 08:29 AM
  3. Help me stock up!
    By Big Boi in forum Auto Detailing 101
    Last Post: 01-17-2013, 09:56 PM
  4. When will the Gtechniq exo be back in stock?
    By fenderpicks in forum Off-Topic
    Last Post: 01-14-2013, 04:25 PM
  5. FK 425 1 gal. out of stock
    By Emm in forum Products Guides
    Last Post: 05-11-2011, 01:27 PM
