Re: Gtechniq EXO - IN STOCK!
Originally Posted by Waxmax
Issues...what kind?? Are they using IPA or Eraser after polishing or prewax cleaning....or are they trying to remove a previous LSP?
If I remember correctly, they're seeing the product fail after several weeks - and yes, it was to remove polishing residue, not to remove LSPs. My take is that if you're spending that kind of money on a product, you might as well follow the manufacturer's instructions to the letter - including their instructions on prep, as well as the required temperature during application
Good hint
So would quick detailers/ waterless wash to clean the vehicle have any ill effects over exo? I never use soap and water anymore.
what about washing the car with stripping dilution of CG citrus wash or something of that nature.
You can wash with whatever, but you should do a final wipe down with a body shop safe silicone remover like Panel Wipe or Prep Sol.
To Rob at Gtechiq...
Now you see why I was asking you about the prep wipe recommendations?
heh - got it
are you planning to stock panel wipe? we can ship from over here in tea-bag land but seems a bit daft to be lugging such a commonly available product across the pond
Originally Posted by gtechrob
heh - got it
That's out of my area of influence. My areas of responsibility are on the education, demonstration side of things...
I know the online audience and I knew this is the direction this thread or a similar thread would take sooner or later because the online detailing enthusiasts and pro detailers tend and trend to be OCD and they want specific information when using a product like EXO.
Heck, I'm the guy that didn't want to write this article but had to because of all the bad information being recommended by others.
How to Mix IPA for Inspecting Correction Results
Key to the performance of any product is following the manufactures directions because since they engineered the product they know best how to use it. When it comes to Gtechniq EXO a HUGE part of product performance is prepping the surface.
I'm confident we will remove all the swirls and scratches Thursday night out of the very exotic paint job on the 1965 Fastback Mustang using Pinnacle Polishes by machine.
What I want to show during the *live* broadcast that will also be recorded and then shared on YouTube into the future will be,
- A technically correct procedure
- A safe procedure
- A procedure an enthusiast or pro detailer can duplicate without having to be a scientist.
We have a number of products on Autogeek.net that can be used to strip compound and polish residues off paint, the key is to find one that will do so while at the same time not mar or scratch the paint which is what I call working backwards.
Most chemicals that offer enough solvent or dissolving ability are not at the same time good LUBRICANTS and therein lies the problem. Wiping perfectly polished paint with something that will also induce marring is a working backwards.
I like how Mineral Spirits wipes over polished paint, it's fairly good at letting a microfiber towel glide over the paint, at least better than most solvents.
IPA and Water is okay.
I haven't used Prep-All for years but I can pick some up and give it a try. Just for the record, the product is spelled Prep-All, and over the last three years I've typed the name and included a picture enough that it can be found by doing a search on the forum as long as a person includes the hyphen between the two words, Prep and All.
Dr. David Ghodoussi has created formulas for Klean-Strip in his years of being a chemist and I spoke with him about this product and he said that since the stricter EPA laws went into effect the VOC content has been reduced but it is still an effective surface cleaning solvent.
I'll do some testing today to see what wipes best, I've done some of this in the past and you can see high resolution pictures on black paint here,
Hologram Free with a Rotary Buffer
And of course, to date no one has ever challenged what I wrote in the above article.
Ha...
After posting the above I did my normal morning check of Private Messages and there's a question asking me about using Prep-All to prep paint for EXO
hi mike,
fully with you on not going backwards. nothing worse than have to re-correct a car as something in a cloth has marred the surface. always feel like this is like a balancing act particularly with dark soft finishes and it's where the never ending detail where hours turn into minutes can begin.
our mantra is to touch the finish as little as possible - I hate seeing people clay cars that don't need it and cutting paint too hard. we also specialise in super-yachts - can't tell you the amount of times I have been down to a maintenance yard and seen big apes of guys hitting near perfect polyester urethane finishes with cutting compound thereby taking all the protection out of the paint - unbelievable - particularly when a repaint on a 150' yacht is going to be over $1million.
with panel wipe - there is no reason it's going to introduce marring into the finish other than through the cloth being slightly abrasive. the only other thing that might happen (and I rule you out for this Mr Mike!!) is that the panel wipe removes masking agents from a polish revealing marks that haven't been fully corrected.
But I think what everyone is asking is...We can't get panel wipe...What can we use in place of this? Correct me if I am wrong about what the question is.
By AV8R in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 01-06-2020, 08:49 AM
By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
Last Post: 04-19-2018, 08:29 AM
By Big Boi in forum Auto Detailing 101
Last Post: 01-17-2013, 09:56 PM
By fenderpicks in forum Off-Topic
Last Post: 01-14-2013, 04:25 PM
By Emm in forum Products Guides
Last Post: 05-11-2011, 01:27 PM
