Super Moderator
NEW 3M Electric Variable Speed Rotary Polisher
The 3M Electric Variable Speed Rotary Polisher balances speed and power with operator comfort. Remove scratches, swirls, oxidation and more with precision and control. The 3M Electric Variable Speed Rotary Polisher has a powerful 11 amp motor with 37.5% more power than 8 amp polishers. Superior construction and user-friendly features make the 3M Electric Variable Speed Rotary Polisher a true professional grade polsiher.
The 3M Electric Variable Speed Rotary Polisher is a paint-correcting machine! It's built for fast, effective removal of paint imperfections with the 11 amp motor and operating speeds of 1,000 - 3,000 rpm. The electronic variable speed control maintains speed and power even under load. The variable speed control trigger allows the operator to vary the speed below the selected maximum speed for greater control over polishing speed. Work at a slow speed for general polishing or speed it up for paint correction. A heavy duty trigger lock allows you to lock in your desired speed.
Features:
11 amp motor
1,000-3,000 rpm
double-insulated 14 gauge, 10 ft. power cord
push button spindle lock
7.9 lbs.
5/8" x 11 spindle
Re: NEW 3M Electric Variable Speed Rotary Polisher
looks kind of nice. will it be better then a 3403. hmm
I'm no rotary guru, but don't alot of people like to use less than 1000 rpms, to spread and refine polishes?
Looks like a well built machine but i do like the option to go to a lower RPM and the Makita lets you do that .
It weighs almost twice what a 3403 does.
For the price point, I think the Flex PE14-2 150 is the better deal, even if it does cost slightly more.
If you're looking to stay under $300 I'd still go to a Makita first.
By VTHokie in forum Flex Polishers
Last Post: 08-21-2014, 01:07 PM
By Mike Phillips in forum Cyclo Polishers
Last Post: 03-07-2013, 01:49 PM
By SPIROS ANTONIOU in forum Rotary Buffers
Last Post: 11-24-2011, 10:11 AM
By m5allen in forum Auto Detailing 101
Last Post: 12-09-2009, 12:12 PM
By Z06-Goose in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-22-2007, 10:29 PM
