Super Moderator
NEW Meguiars Sanding Paper and Blocks
Unigrit technology leaves a smooth finish that buffs out quickly!
Meguiars Unigrit Sand Papers remove deep scratches and orange peel and leave a smooth, even finish that buffs out easily. The tiny abrasives level the paint without the risk of deep sanding scratches. Meguiars Unigrit Sand Papers are waterproof, durable, and clear coat safe. For automotive wet-sanding, Meguiars Unigrit Sand Papers are the professional’s choice.
Remove paint drips and runs quickly and conveniently.
Meguiars Unigrit Sanding Blocks are the easiest, most efficient way to remove paint drips, sags, and other blemishes on top of the paint. Uniformly sized abrasives level the imperfection with the surrounding paint, leaving an even pattern of sanding scratches. The light sanding marks are then easily removed with a buffer. Meguiars Sanding Blocks are designed to turn a good paint job into a perfect paint job.
Re: NEW Meguiars Sanding Paper and Blocks
I was just thinking of picking this stuff up from another source for a bit more$. You guys keep adding more and more products at an impressive rate.
Woo Hoo, i like this. Hey Meghan, do you know of any kits that would come with say 2000,2500, 3000 grit all together? I know those are awfully high grits but it was just an idea. Or would i just have to stick to buying each separately?
ADS sells it by the sheet so you can miz n match.
Last Post: 04-15-2020, 09:39 AM
By EvolutionDetail in forum Auto Detailing 101
Last Post: 03-23-2014, 03:29 PM
By cobraa in forum Wet-Sanding, Cutting & Buffing
Last Post: 09-23-2010, 11:26 AM
By Garry Dean in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-16-2010, 06:07 PM
By Adde in forum Off-Topic
Last Post: 07-03-2006, 09:31 PM
