Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Administrator
    Feb 2022
    Port St. Lucie, FL
    It's Finally Here! FLEX FS-140 Flexible Shaft Set for the PXE 80
    MSRP: $299.99
    The FLEX FS-140 Flexible Shaft Set is the perfect extension to your FLEX PXE 80! This ingenious invention by FLEX gives your FLEX PXE 80 a flexible extension shaft, allowing you to extend its polishing power to any nook or cranny on your vehicle! Polishing behind door handles, between wheel spokes, between grille slats, in and around hood vents, and so many other areas is not a problem anymore! The FLEX FS-140 Flexible Shaft Set attaches to your FLEX PXE 80 using a quick-connect mechanism! Once attached, the FLEX FS-140 Flexible Shaft Set translates the circular motion along the flexible shaft to one of the many polishing heads included in the kit! This means you won't have to worry about being able to maneuver your polisher to polish the surface! Instead, you'll be able to polish any area where you could maneuver a pen! And the flexibility of the shaft means you will be able to reach into niche areas from pretty much any angle with ease! Just when you thought your FLEX PXE 80 couldn't get any better, the FLEX FS-140 Flexible Shaft Set is here to take it a step further!
    When FLEX first released the PXE 80 polisher, many detailers were instantly impressed with the versatility it had, allowing them to polish areas they simply couldn't reach with other polishers! However, in their never-ending pursuit to provide detailers with the tools that won't limit a detailer's skills, FLEX created the FLEX FS-140 Flexible Shaft Set to make the already extremely versatile FLEX PXE 80 capable of polishing virtually ANYWHERE! The ingenious design of the FLEX FS-140 Flexible Shaft Set extends the polishing power of the FLEX PXE 80 to anywhere you could fit a pen!
    The FLEX FS-140 Flexible Shaft Set uses the same quick-connect mechanism that the other FLEX PXE 80 heads use, making it a breeze to swap back and forth! You won't have to grab a different machine or spend time unnecessarily wrestling with a new backing plate or pad, just pop out the old head, and pop in the new one! No need to break your polishing flow!
    There are an nearly unlimited number of uses for the FLEX FS-140 Flexible Shaft Set, but just to give you a few ideas of all the areas that will now be a breeze to polish, here are some ideas:
    Behind door handles
    Between grille slats
    Around wheel spokes/rims
    Inside hood vents
    Between gaps in emblems
    In door jamb crevices
    The inside edge of your exhaust
    Piano black interior finishes
    You've never had as much polishing power as you will have when you use the FLEX FS-140 Flexible Shaft Set with your FLEX PXE 80!
    FLEX FS-140 Flexible Shaft Set includes:
    Flexible Shaft
    Allen Key
    Rotary Drive Mechanism
    2 Cylindrical Cutting Pads
    2 Cylindrical Polishing Pads
    2 Cylindrical Finishing Pads
    2 Conical Cutting Pads
    2 Conical Polishing Pads
    2 Conical Finishing Pads
    FLEX PXE 80 polisher sold separately.
    Michael W.
    Autogeek Customer Service Manager
    (772) 247-3421
    Michael@autogeek.com
  2. Likes Bruno Soares liked this post
  3. #2
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,922
    Re: It's Finally Here! FLEX FS-140 Flexible Shaft Set for the PXE 80
    Very nice. Be a great addition, just a bit pricey!
    Scott Harle
    Autodermatology
    #autodermatology
  4. Likes The Guz, Coatingsarecrack, luckydawg, opie liked this post
  5. #3
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Sizzle Chest View Post
    Agreed. More than a bit pricey considering the cost of the PXE.
  6. Likes luckydawg liked this post
  7. #4
    May 2013
    TN
    1,768
    Yes. $200 would be hard to swallow but I’d consider it. $300 is overboard in my opinion. Not blaming AGO as I’m glad they’re carrying it but Flex must not expect to sell very many at that price, which is going to become a self-fulfilling prophecy.
  8. Likes noorth, DanaDetailingPros liked this post
  9. #5
    Mar 2017
    Southeastern PA
    2,482
    I don’t understand what makes it so expensive. Must be made in Germany, if this came from China it would be under $100.
    Bruno Soares
  10. Likes luckydawg liked this post
  11. #6
    SELF BANNED
    Jun 2019
    1,076
    Not much equipment for $300 that's for sure. You think that you would get at least 50 pads..and maybe an extra battery lol
    That little PXE 80 looks fantastic though.
  12. Likes luckydawg liked this post
  13. #7
    Super Member Rsurfer's Avatar
    Jan 2007
    14,115
    Is Flex trying to get their R&D cost from AG members?
  14. Thanks noorth thanked for this post
    Likes chilly, PaulMys, luckydawg liked this post
  15. #8
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    $300 for a flexible rotary shaft and 12 tiny foam pads??
  16. Likes luckydawg, opie liked this post
  17. #9
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Quote Originally Posted by Bruno Soares View Post
    It more than likely did come from chyna
    I know for a fact flex started farming out their electric motors to chyna several yrs back
    Diplomacy is the art of telling people to go to hell in such a way that they ask for directions-- Winston Churchill
    The difference between genius & stupidity is genius has limits-- Albert Einstein
  18. Likes PaulMys, dgage, mbkite liked this post
  19. #10
    Super Member theamcguy's Avatar
    Dec 2007
    Fayetteville, NC
    260
    Pricey is not the word, unreasonable is the word. AG has the PXE80 kit with the polisher, 2 batteries, 3 heads for $399, that's only $100 more than the flexible shaft kit. It is not AGs fault, Flex's price is $299 for this tool but even though the tool is fantastic the price is way unreasonable for what you get. You get a flexible shaft and 12 expendable polishing pads. I really want the tool but the price makes me pause. It's not the money per se but what you are getting for $300 12 expendable polishing pads and a cable.
    Bill Strobel
    Owner Independent Towing & Repair
    Fayetteville, NC
    Do It Right or Don't Do It At All
  20. Likes dgage, noorth liked this post
  1. Flex PXE80 -Official 2" backing Pad and Flexible shaft
    By nickyc in forum Flex Polishers
    Last Post: 08-28-2021, 11:24 AM
  2. Finally got to use my Flex
    By kjn in forum Auto Detailing 101
    Last Post: 11-17-2013, 02:52 PM
  3. 7424XP- Shaft came out
    By CornDwg01 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-23-2011, 08:27 PM
  4. Finally Got To Use My Flex
    By Dubbin1 in forum Flex Polishers
    Last Post: 05-08-2010, 01:57 PM
  5. Finally got my Flex!
    By Excessive Detail in forum Auto Detailing Tools and Accessories
    Last Post: 02-08-2008, 03:20 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
