Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 65
  1. #31
    Super Member Craig Encinitas's Avatar
    Jul 2020
    312
    Re: SEMA 2020/2021 New Products
    TiO2 is also used in CQuartz Light.
    ...helps with reflectivity, I think?
    I’m looking forward to this new Si component.
  2. #32
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Introducing the heaviest, most powerful cutting compound CARPRO has created yet. - CARPRO Ultracut!
    Ultracut contains a cocktail of fully diminishing abrasives, which correct heavy defects, while producing minimal haze.
    ​Combine it with the CARPRO cutting pads (wool, flash, cool) or microfiber for extremely effective and efficient defect removal. Drop down to CARPRO orange polishing pad and you can finish down hologram-free.
    Ultracut is a perfect solution for rotary or DA polishing with extremely low dusting and a lubricant that allows the abrasives to be worked for an extended period. This allows total breakdown with less marring and holograms.
    If I recall (reading most my info from you in the past, Guz)...CQ TiO2 was slick and nice looking (maybe even comparable to Gliss topping) but didn’t have either longevity or protection or self-cleaning (functionality) of UK.
    Sorry if I’m totally wrong, I figured some here including myself could use the recap.
    I had both UK and TiO2 still doing well at 24 months. TiO2 had better stain resistance and UK has the hardness.
    Quote Originally Posted by Craig Encinitas View Post
    Lite’s backbone is UK 3.0. But it does have TiO2 in it as well.
  3. Thanks mc2hill, Craig Encinitas thanked for this post
    Likes Craig Encinitas, PaulMys, JustJesus, Loach liked this post
  4. #33
    Super Member VISITOR's Avatar
    May 2007
    9,730
    New Products (adding to post #2 on the 1st page)
    Ceramic Speed Shine
    The World's best spray detailer now with SiO2 protection. It features an exclusive blend of advanced silane polymer technology combined with SOo2 to maintain an ultra-slick, insane- gloss finish in between more significant washing and protection processes.
    -Everything you love about Speed Shine® plus SiO2 protection
    -Super slick, ultra-hydrophobic finish
    -Can be used as clay or surface prep tool lubricant for paint decontamination
    -Safe on all exterior surfaces and paint protection film
    Ceramic Wash & Coat
    Ceramic Wash & Coat is an exciting new wash option that is formulated to safely clean exterior vehicle surfaces, safely removing abrasives and road grime while imparting an effortlessly durable coat of SiO2 infused ultra-hydrophobic silane polymers. Ideal for maintenance of ceramic coated vehicles or as stand-alone exterior protection.
    -Add SiO2 Ceramic protection every time you wash your vehicle
    -Versatile formula can be used with a multitude of wash tools
    -Low sudsing, lubricant rich formula imparts durable protection
    -Use with other Griot's Garage Ceramic products for ultimate protection
    -Safe on paint, exterior trim, wheels, and glass
    Trim & Detail Coating (Aerosol)
    Tar-Bug-Sap Remover (Aerosol)
    Foaming Carpet & Upholstery Cleaner (Aerosol)
    Surface Disinfectant
    Griot's Garage Surface Disinfectant is great for everyday use on interior materials of cars, trucks, RV's and even your home. It effectively cleans, deodorizes and disinfects a multitude of automotive interior surfaces.
    -Safe for use on door panels, steering wheels, dash boards, door handles, center consoles, vinyl, leather, plastic, and more
    -Kills Covid-19, Influenza A, Rhinovirus, E-coli, Salmonella, MRSA, and more
    -Versatile formula capably cleans, deodorizes, and disinfects in one simple process
    -No added dyes or fragrances
    -Be sure to follow all directions in order to fully disinfect intended surfaces
    Odor Neutralizing Carpet & Upholstery Cleaner
    Carpets and upholstery can be one of the more difficult automotive surfaces to clean. This cleaner uses a unique hydrogen peroxide based technology for a truly deep clean.
    -Advanced peroxide formula eliminates stains and odors fast
    -Unique encapsulation technology prevents re-soiling after cleaning
    -Use on interior carpets, floor mats, upholstery, micro fiber seats, household fabrics, and pet stains
    -Rich foaming action penetrates soiled fibers allowing efficient stain removal
    -Great for removal of organic and oil based stains
    -User friendly scent and dye free formula
    Ceramic Trim Wipes
    Stop patching over a problem and discover a true solution to faded, discolored trim with this easy to use kit. Our Ceramic Trim Wipes powered by Cerakote® Ceramics easily restore damaged and faded trims.
    -Extremely durable ceramic protection in an easy to apply wipe
    -ASMR tested up to 200 washes or 2 years of durability
    -Extreme UV and stain resistance
    -Kit contains 4 wipes and one protective nitrile glove
    -Each wipe can treat up to 20 square feet of trim
    Ceramic Headlight Restoration Wipes (Moderate)
    Restore your moderately oxidized and underperforming headlights to like new clarity. Our Ceramic Headlight Coating powered by Cerakote® Ceramics is the only ceramic headlight coating on the market and is guaranteed to last for life.
    -Easy to use kit restores optical clarity in less than 30 minutes
    -Ceramic Headlight Coating guaranteed for life
    -Easy to use kit does not require power tools
    Ceramic Headlight Restoration Kit (Severe)
    Restore your severly oxidized and underperforming headlights to like-new clarity. Our Ceramic Headlight Coating powered by Cerakote® Ceramics is the only ceramic headlight coating on the market and is guaranteed to last for life.
    -Lifetime Ceramic Headlight coating prevents future lens failure
    -Complete kit is easy to use and requires no power tools
    -Kit includes everything you need to restore severely oxidized and yellowed headlight lenses
  5. Thanks RamAirV1 thanked for this post
  6. #34
    May 2017
    Pittsburgh PA
    2,847
    Griots officially in the ‘ceramic’ game.
  7. #35
    Jun 2013
    LA, CA
    8,719
    We are proud to announce CQUARTZ Leather 2.0, which is a natural evolution of the world-renowned leather and vinyl coating – CQ Leather.
    ​The new formula is water-based and therefore safe to use on all types of leather, including Nappa leather. The new Leather 2.0 not only improves on the hydrophobic, self-cleaning properties, as well as resistance to UV, denim dye coloring, abrasion and stains.
  8. #36
    Jun 2013
    LA, CA
    8,719
    Ceramic Trim Wipes
    pics as they become available...
    Interesting that they paired with cerakote for those wipes and headlight kit.
  9. #37
    Apr 2012
    604
    Has it been mentioned anywhere how the new coating compares to UK 3.0?
  10. #38
    May 2007
    9,730
  11. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  12. #39
    Super Member 2wookies's Avatar
    Jul 2015
    367
    Quote Originally Posted by RZJZA80 View Post
    Also still waiting for better clarification. If it’s a TIO2 replacement, doesn’t this mean Uk is still the stronger?
    What’s the difference between the two??
  13. #40
    Aug 2013
    St Louis metro (Illinois)
    5,811
    Ceramic Trim Wipes
    Is this coming from e-mail you receive? I'd really like to find more information on their new products, but not finding anything on their website.
    Griots products really catch my attention, and I don't really know why. I've used their wheel cleaner for a long time and like it. I now own a G15 and am really impressed. However, I've never really used any of their other products, but constantly find myself browsing their BOSS polishes and their new 3-1 ceramic spray.
  1. NEW 2020 3D Products Videos
    By Mike Phillips in forum How to Videos
    Last Post: 02-17-2020, 07:46 PM
  2. SEMA 2019 New Products - New Products Coming Soon!
    By VISITOR in forum New Car Care Products
    Last Post: 01-05-2020, 09:33 AM
  3. Replies: 12
    Last Post: 10-27-2019, 03:34 PM
  4. Replies: 9
    Last Post: 12-10-2016, 09:13 PM
