Car Pro New Products...
CarPro EliXir Quick Detailer
Magic in a bottle!
CarPro EliXir Quick Detailer was created to combine the incredible hydrophobicity of a ceramic coating with the quick and easy application of a quick detailer. The results you get out of CarPro EliXir Quick Detailer are sure to completely change your perception of the capabilities of a quick detailer. CarPro EliXir Quick Detailer provides an infinitely deep gloss that will leave your care looking like you spent the whole day laboring over it carefully. Not to mention that CarPro EliXir Quick Detailer will make water bead and roll off your car at an alarming rate!
There are many different types of contaminants to which your car is subjected. Each of them has varying level of severity and resolve. Of course, there are the incredibly tough contaminants that require nothing short of compounding remove effectively, but the clear majority of contamination is minor and light. Even this light contamination can still ruin a flawless shine. When you need to remove it effectively, there is no point in busting out your wash buckets and hose just to get rid of some light dusting 3 times a week.
CarPro EliXir Quick Detailer gives you the perfect solution to this unavoidable issue that all car owners face. Instead of needing to wash your entire vehicle to get rid of this contamination, CarPro EliXir Quick Detailer can be used to quickly and safely remove the light soil from your paint. All you have to do is spray CarPro EliXir Quick Detailer on, buff it in, and buff it off!
Simply spray CarPro EliXir directly onto the panel being treated and buff off!
CarPro EliXir Quick Detailer will do more than just remove light contamination from your car. CarPro EliXir Quick Detailer is designed with incredible polymers that will work effortlessly to provide an intense level of shine to your paint.
Probably the most important aspect of CarPro EliXir Quick Detailer is the hydrophobic qualities it instills in your paint. CarPro EliXir Quick Detailer greatly increases the tension on the surface of your car, preventing any water from being able to collect on the surface. Instead, the water will bead up on the paint without sticking. Now whenever you move your car or even if a light breeze goes by, the water will roll right off harmlessly!
Directions: 1. Shake well 2. Spray half a panel sparingly 3. Immediately spread even, buff in, and buff off 4. Use a clean “final wipe” towel and check for perfection before moving to next section or panel.
Our Price: $18.99
Sale price: $17.95
CarPro MultiX All Purpose Cleaner Concentrate
You don’t need a garage full of cleaners to have a clean car!
CarPro MultiX All Purpose Cleaner Concentrate was designed as a versatile and effective “Jack of all trades” cleaner. The powerful cleaner agents contained in CarPro MultiX All Purpose Cleaner Concentrate are capable of handling any mess; spanning from light soil on your windshield, all the way to the heavy grime on your tires and engine bay. CarPro MultiX All Purpose Cleaner Concentrate will save you a ton of money thanks to its high concentration ratios and the fact that you won’t have to buy a separate cleaner for each surface of your vehicle.
There are so many different types of surfaces and contamination that your car is exposed to that it can be quite cumbersome to keep up with all the different recommended products to care for them. There are different products recommended for glass, paint, metal, plastic, and any other surface you can think of. Additionally, a cleaner that is designed for clean the dust off your dash won’t do anything to the road grime on your wheels and trim.
CarPro MultiX All Purpose Cleaner Concentrate, on the other hand, was designed to address pretty much every possible mess your car will ever experience. CarPro MultiX All Purpose Cleaner Concentrate was designed using advance cleaner agents that are incredibly effective at tackling stubborn messes. This means that when you are looking to breakdown the oily residue that has collect on your engine bay, CarPro MultiX All Purpose Cleaner Concentrate will take care of it in minutes.
___________________
After diluting to your desired strenght, the CarPro Multi X can be used to clean virtually ANY surface!
If, however, you are working on the delicate carpeting in your interior, a stronger cleaner might damage the fibers and permanently discolor the carpet. CarPro MultiX All Purpose Cleaner Concentrate is still the answer to your problem though! CarPro MultiX All Purpose Cleaner Concentrate can be diluted to many different ratios. When you dilute it, the effective cleaner agents are still there, but there is less of them. So, the cleaner is still quite effective, but there isn’t any risk to your carpet now that CarPro MultiX All Purpose Cleaner Concentrate is properly diluted!
As detailers, we tend to spend an enormous amount of money on keeping our car clean. So much so, in fact, that we often have so many bottles in our garage that we are unable to park our car in it! CarPro MultiX All Purpose Cleaner Concentrate cuts down on this drastically by storing all your cleaners in one bottle!Just simply dilute CarPro MultiX All Purpose Cleaner Concentrate to match the mess and surface, and you are on your way to a perfectly clean surface!
Dilutions:
• Pad Cleaner 1:10 ~ 1:20
• Pre-Wash: 1:1 ~ 1:20
• Tires: Neat ~ 1:10
• Engine Bay: Neat ~ 1:20
• Streaks: Neat ~ 1:20
• High Pressure cleaning 1:100
Directions:
Always be sure to test CarPro MultiX All Purpose Cleaner Concentrate on an inconspicuous area before each use.
• Dilute to suit desired purpose and surface
• Spray, foam, or saturate surface
• Agitate as needed
• Rinse thoroughly
Our Price: $16.99
Sale price: $15.95
CarPro GlassFiber Microfiber Towel
A revolutionary new glass cleaning towel!
The CarPro GlassFiber Microfiber Towel was designed to maximize cleaning potential and minimizing streaking while you are cleaning your glass. The thin sponge core of the CarPro GlassFiber Microfiber Towel absorbs more of your window cleaner and thus increases its cleaning abilities! The specially designed exposed microfiber structure of the CarPro GlassFiber Microfiber Towel reduces the streaks due to the lower amount of friction is generates.
One of the most dreadful things to see after you take the time out of your day to clean the road grime off of your glass is a windshield full of streaks. There are two main causes of streaks while you are cleaning your window, the towel’s drag and inadequate cleansing of the grime on your glass.
The towels drag is mainly caused by the long fibers that most towels have. While these long fibers are usually great for a nice soft touch, they tend to drag behind the towel afterwards and leave trails of grime behind them. These trails are known as streaks. The CarPro GlassFiber Microfiber Towel reduces this risk by having an exposed microfiber structure. This exposed microfiber structure has a shorter nap, those creating less drag during cleaning!
Even if you are using a towel with a shallow nap, streaks can still be caused if there is an abundance of grime left on the glass. This grime is usually dissolved and broken up by your glass cleaner and absorbed by the towel, but if your towel isn’t able to absorb all grime, you will still get streaks. Luckily, the CarPro GlassFiber Microfiber Towel contains a thin, sponge-like core that improves the absorbency of the towel. Because the CarPro GlassFiber Microfiber Towel is easily able to absorb all the grime off your glass, streaks will be a thing of the past!
The CarPro GlassFiber Microfiber Towel also has a lint-free design that makes it extraordinarily easy to clean and maintain. Couple that with its sturdy fiber structure and you have a towel that will clean your glass well into the future!
Our Price: $9.99
Sale price: $8.95
CarPro Dhydrate Drying Towel
The safest drying towel out there!
The CarPro Dhydrate Drying Towel will revolutionize your entire car drying process! The easy with which the CarPro Dhydrate Drying Towel can engulf every drop of water on your vehicle will leave you so amazed you may need it to dry the drool off your chin!
The CarPro Dhydrate Drying Towel was designed to create as little drag as possible to avoid washing swirls and scratches while you are drying. The CarPro Dhydrate Drying Towel will glide effortlessly across the surface of any paint, treated or untreated, coated or uncoated. All without damaging the existing protection that is on your car already.
Due to the extreme absorbency of the CarPro Dhydrate Drying Towel, drying your paint off could not be any easier. Simply lay the CarPro Dhydrate Drying Towel across the surface you are drying and slowly drag it across. That’s it, you are now ready to move on to the next surface without worrying about any water being left behind to evaporate and cause water spots.
If it isn’t enough that the CarPro Dhydrate Drying Towel is made with materials that will greatly reduce the risk of scratches and swirls, the light grey color of the CarPro Dhydrate Drying Towel makes it incredibly easy to spot any dirt or debris that may gather in it fibers. This means that it would be nearly impossible for you to accidently drag a debris-riddled towel across your perfect detailed paint!
If that still isn’t enough for you to feel confident in your paint’s safety while using the CarPro Dhydrate Drying Towel, this towel has even more scratch reducing properties! The CarPro Dhydrate Drying Towel is made with an edge made of microfiber, not piping. This means that the edges won’t cause any scratches during use. Combine that with the fact that it tagless and you would be hard-pressed to find something on this towel that is capable of scratching your precious paint.
The CarPro Dhydrate Drying Towel is durably made and is designed to be completely lint free. Making it extremely easy to clean and ready for use after use without wear!
Our Price: $15.99
Car Pro Tire Swipe Applicator
The ideal tool to dress any tire!
The Car Pro Tire Swipe Applicator was designed to make applying a tire dressing to you tires as easy and efficient as possible. There are so many different types on tires and wheels out there that it can be difficult to find an applicator that is able work effectively on all of them. It is for this very reason that the Car Pro Tire Swipe Applicator was designed with a unique asymmetrical radius that allows you to apply a tire dressing or gel to the outer edge of your tire without covering your rims in the stuff!
You will experience a noticeable increase in durability when you compare the Car Pro Tire Swipe Applicator to other tire dressing applicators that are on the market today. The Car Pro Tire Swipe Applicator was designed with a tough steady grip handle, so it can stand up to repeated use and abuse!
The Car Pro Tire Swipe Applicator is made with a much denser foam that keeps more of the dressing or gel on the surface of the tire. This means that your tires are able to absorb more of your dressing and you will receive better results from your chosen tire protection! Whether you want your tires to be matte black or high shine, the Car Pro Tire Swipe Applicator will make sure you get the best finish your tires have to offer!
Our Price: $2.50
Sale price: $1.95
Last Post: 12-28-2018, 02:56 PM
By VISITOR in forum New Car Care Products
Last Post: 10-22-2018, 12:45 PM
By RMarkJr in forum Ask your detailing questions!
Last Post: 03-13-2017, 11:14 PM
By Detailing by M in forum Off-Topic
Last Post: 07-03-2013, 06:07 PM
