Re: New 3D ACA Products!
Well was kind of interestes till last comment
@Mwoywod
How donthese work with forced rotation?
All of the 3D green bottle compounds and polishes have always been demoed with a rotary. That should tell you something..............not meant to be used with a DA.
Sent from my LG-H932 using Autogeekonline mobile app
Originally Posted by
custmsprty
Same price point as Wolfgang Total Swirl Remover.............or Pinnacle Advanced Swirl Remover
Probably why I have never felt compelled to try either of them. Too many choices just as good for $20 cheaper.
These products are compatible with a DA
Elliot@Autogeek
They were not developed with a DA in mind.
WRAPT C5Z06
True but here is how I look at it.
Detail Spray wasn't made to use as a Clay Lubricant.
DA sanders weren't for polishing either, it was for actual sanding but someone innovated and used a Meguiar's foam pad to make it work.
Just because something wasn't made for the purpose doesn't mean it won't work.
Of course this doesn't apply to everything but in this case it doesn't matter
Elliot@Autogeek
True, but at THAT price, don't think anyone wants to experiment.
Post Thanks / Like - 0 Thanks, 0 Likes, 1 Dislikes
Well I can’t wait to read the reviews.
Dan Tran
The Buffing Moose Detailing
Today I used the new ACA compound with my Flex PE-14 and the lake country lambswool cutting pad (with the blue foam interface) on a 2002 black single stage toyota 4-runner that had never been polished. It definitely cuts more and runs much cooler than 3D 501 Cutting Compound and HD Cut+. I also tried it with my Rupes 15mk2 and a LC HDO microfiber cutting pad and it didn't provide anywhere near as much cut as it did with Rotary and lambswool.
Personally, most compounds seem to cut more with Rotary and Lambswool for me than with long-throw and microfiber. I know a lot of guys actually feel they get more cut with long-throw/microfiber but like Mark said, with this compound it just didn't provide even close to the same cut and performance as it did when used w/ Rotary.
Post Thanks / Like - 2 Thanks, 5 Likes, 0 Dislikes
Thank you for the review mwoywod.
