Results 1 to 10 of 10
    Jul 2013
    49
    Removing oxidation on an aluminum engine custom bike
    Hey guys, I need to remove the oxidation on an aluminum engine on a custom motorcycle. I was looking into a product called aluminate but not sure if it would be ok to use on an engine.
    Dec 2014
    Boonsboro, Md
    2,724
    Re: Removing oxidation on an aluminum engine custom bike
    Acid based Aluminum cleaners/brighters like the one you listed will only remove light oxidation from my experience. If you are talking about the crusty white oxidation, some agitation with a cleaner may help some but the surface may not look great after. There may be pitting, spotting, and a general haze leftover that would need to de sanded out to look better. Quite a task on a motorcycle engine if it's in bad state.
    If it's just lightly oxidized/milky looking, the cleaner/brighter should brighten it up some.
    I'm not sure how safe it would be to use on a motorcycle engine. You may have to worry about overspray on certain materials.
    ____________
    Jul 2013
    49
    Thats what I was worried about. I also don't want it to turn out "blotchy" if you know what I mean.
    Super Member brettS4's Avatar
    Jan 2015
    Wisconsin
    649
    Have you tried Bar Keepers Friend?
    Jul 2013
    49
    How well does it work?
    Jan 2015
    Wisconsin
    649
    I've never tried it on an engine but it's amazing on stainless steel surfaces. It's similar to using Comet... just mix some powder with water to whatever consistency you want and do a little scrubbing. I have no idea if it will do what you want, but since you can get it in just about any grocery store, Home Depot or someplace similar, and costs only about $4, it's worth a shot. Use it with a mild scotchbrite pad.
    Feb 2013
    San Antonio, Tx
    114
    I haven't used it but Flitz has this aluminum precleaner that seems to work great. Mike did a post on it I believe along with some pics and vids.
    Super Member HateSwirls's Avatar
    Jun 2013
    3,632
    If it's really bad wet sanding may be needed.
    I just restored a 1983 Honda CM400A
    The engine covers were awful,I sanded with 400, 600, 1000, then 1500.
    Afterwards I started polishing using the brown and white compound brick, came out looking like chrome.
    Sent from my iPad using Autogeekonline mobile app
    cajundetailingbykevin.com
    vpcajun@gmail.com
    May 2007
    680
    BKF is a acid. Not recommended for alum.
  10. #10
    Dec 2014
    Boonsboro, Md
    2,724
    I wouldn't use it on good condition or highly polished raw aluminum, but I would use it or do use acid brighteners on heavy oxidized raw aluminum prior to polishing.
    ____________
  1. Removing chalky oxidation on an aluminum engine
    By 11BeachGT500 in forum Ask your detailing questions!
    Last Post: 08-20-2016, 05:53 PM
  2. Custom Bike Detail - B & B Detailing - Nashville Tn
    By Bates Detailing in forum Show N' Shine
    Last Post: 03-24-2012, 09:00 AM
  3. removing aluminum trim oxidation
    By stevehecht in forum Ask your detailing questions!
    Last Post: 09-14-2009, 08:53 PM
  4. Custom Bike w/ unique paint
    By shadybreal in forum Show N' Shine
    Last Post: 10-20-2007, 08:29 PM
  5. Arlen Ness Custom Bike
    Last Post: 10-14-2007, 03:25 PM
