Results 1 to 5 of 5
    Mar 2015
    swirls or sand paper marks?
    Hi, my first post except introduction,i have a newly painted inner fairing that i got done from a guy in florida,well the media door and the other side that looks like a door ,has like swirl or sand paper marks ,i tried turtle wax scratch stuff by hand but didnt touch it,i am very new to this but what could i use by hand to get this out,hope i make since,thanks
    Super Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,791
    Re: swirls or sand paper marks?
    It's hard to say for sure what caused the defects without seeing a picture; however, since it is a freshly painted panel it is highly likely that you are dealing with sanding marks that were not fully polished out by the body shop.
    If it is, in fact, sanding marks that you are dealing with then it is going to be extremely difficult to remove them by hand. It's possible, just ridiculously time consuming. Machine polishing would save lots of time and produce a better end result. With that being said, if you are hell bent on doing this by hand, my suggestion would be to pick up some CarPro 3" Flash Pads and Meguiar's M105. This combo will lay waste to 1500g sanding marks (even by hand). Oh, and toss the Turtle Wax stuff in the garbage. It's worthless.
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
    Junior Member J Cole's Avatar
    Jan 2015
    71
    Quote Originally Posted by bobbyjos55 View Post
    I'd ask the guy about it first - he should be able to properly finish it for you.
    Super Member davey g-force's Avatar
    Aug 2009
    1,225
    Quote Originally Posted by J Cole View Post
    Yeah... then you just have to remove his holograms
    Quote Originally Posted by Jason Rose
    Mar 2015
    yah i asked him ,he said use a mild compound to remove,he said the lighting in his shop wasnt good because he was moving into new shop,just so they come out ,still cheaper then harley fairing if they come out,thanks so far
  1. forgot to wet sand paper, what to do?
    By PointClickKill in forum Auto Detailing 101
    Last Post: 06-21-2019, 12:11 PM
  2. What are the must have sand grit paper for Headlight Restoration
    By NiSyam in forum Ask your detailing questions!
    Last Post: 05-07-2012, 11:53 AM
  3. Newbie with Sand Paper
    By Sai venkatesh in forum Wet-Sanding, Cutting & Buffing
    Last Post: 04-08-2012, 11:40 AM
  4. Need Help With Sand Paper Flap Wheel
    By StaySolitude in forum Rotary Buffers
    Last Post: 12-14-2011, 11:09 PM
  5. Clay bar sand paper effect ?
    By DaC in forum Auto Detailing 101
    Last Post: 09-19-2011, 05:32 PM
