melted boot on exhaust
Just curious what products you guys use to safely remove melted boot rubber off the exhaust pipe.
Re: melted boot on exhaust
Melted boot rubber on an exhaust..I've never seen this. Could you post a pic of what you talking about?
I'm trying to think of what rubber is around an exhaust and other than some rubber on the mounting brackets for an exhaust I don't know if I've ever seen a rubber boot. Sure someone has seen this before though.
I have used a few different things and they all worked for me.
S100 Polishing Soap
On a "warm" (Not HOT) pipe use brake cleaner and spray and wipe 4-5 times with a terry cloth
XXXX steel wool
Then get a boot guard.
Super Moderator
S100 Polishing Soap works great for removing melted Boot rubber.
I will try the polishing soap and see what it does. I have used brake cleaner and even oven cleaner and these two things work great. Im just trying to find something that is not as harsh for customers bikes.
Ahhh melted boot rubber on a bike. I get it now! I was thinking on a car!
The S100 Polishing Soap is the least aggressive but it's a LOT more work.
Fingernail
Popsicle Stick
Plastic Razor Blade
You need something that will scrape or pry the melted rubber/plastic mix off the chrome coating that at the same time won't scratch the chrome coating.
Usually just takes some grunt work with something like I listed above. I've tried using things like Aircraft Quality Paint Stripper and Easy-Off Oven Cleaner to chemically attack, soften and loosen the bond the melted goo has on the chrome, things like this won't hurt chrome.
I've been riding for over 25 years. I would recommend you try the polishing soap first as you want to go from the least to the most aggressive, just exactly as you do with paint. Step up your aggressiveness with 0000 steel wool and a light compound or a metal polish like Autosol. Another great chrome product is Collinite Metal wax. I have very successfully used it with a polishing pad and my rotary to correct some nasty chrome. I have even used it with a small wool pad with amazing results. Try it, you will be amazed!
I use Pro Polish on a wool pad with my rotary and it cleans melted boot rubber of easily. Pretty much any swirl remover will work well with wool pads and it doesn't scratch at all. I'll use a plastic razor blade as Mike has suggested to get the heavier stuff off first.
By Murphy77 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 05-31-2016, 07:04 PM
By Desert Rat in forum Pinnacle Wax
Last Post: 12-12-2015, 11:12 AM
By sloox in forum Auto Detailing 101
Last Post: 07-05-2011, 08:23 PM
By s.mac in forum Flex Polishers
Last Post: 06-20-2010, 06:57 PM
By fast01gt in forum Auto Detailing 101
Last Post: 02-09-2008, 12:25 AM
