Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: Hello from Alaska
    Welcome, Akumatu.
    Jun 2019
    Welcome to the forum.
  3. #13
    Super Member Tasmania's Avatar
    Jan 2017
    Tasmania, Australia
    907
    Hello from Tasmania.
  4. #14
    Sep 2017
    Sweden
    3,022
    Welcome to the forum!
    / Tony
  5. #15
    Aug 2010
    Fairmont, MN
    3,189
    Welcome!
    Lottza GREAT (and good) information Mike shared with ya.
    Curious, what part of Alaska are you from?
    Bill
  6. #16
    Jun 2019
    I looked at their website, found the product you bought and added my comments in blue bold text.
    This kit includes one of each:
    GLARE,Micro-Finish - Fine Cut Polish
    GLARE Spider - Medium Cut Polish
    GLARE Knock-Out Compound - Heavy Cut Compound
    GLARE+ - I'm guessing this is some form of cleaner/sealant also called an AIO
    I've never used GLARE products but I've been asked about them for years in the online world. Their marketing approach, copy (words) and pictures is cheesy at best. I cannot judge if their products are any good because I've never used them before but this I know and I talk about it all the time on this forum and in my detailing classes.
    The MOST important factor when it comes to polishing paint is the abrasive technology. It either works or it doesn't. There is no
    Kind of works
    The abrasive technology used in any product either has the ability to remove defects without instilling defects at the same time or it's simply low quality. I test everyone on black paint. I have a number of tests I do to determine if the abrasive technology is good or junk.
    So here's where your at - the product you bought either work or they don't. The only real way to know is to apply them to black paint and then inspect the results. Usually this will include chemically stripping the paint after application to see the true and accurate results. If a product can make black paint look great it can make any paint look great. If it cannot make black paint look great it cannot make any paint look great. It's that simple.
    People disagree with me on this point and say their "opinion" is that the most important factor is technique, or tool or pad, and while these things are important, if the stuff touching the pant isn't any good then nothing else is going to make it good.
    So do some testing on your car and then do some inspection of the results. Maybe find a black car no one cares about and do your testing on it and once you see great results, then use the products on your car.
    Also - in most cases you would test the least aggressive product first and see if they are able to remove the defects to your satisfaction. If not, you can always test a more aggressive product next.
    If the GLARE+ is in fact some form of all-in-one type product you could start out by just using it. On their website it says,
    Micro scratches, swirls, and oxidation are all removed permanently.
    Using simple common sense, the words removed permanently in context, means the product is abrading the paint or chemically dissolving the paint as a way of leveling the surface with the lowest depths of the defects it is permanently removing.
    If it's not removing paint to level the surface then it is somehow FILLING in the defects permanently.
    As a writer, their statement is very definitive. This is okay if the product actually works but the word permanently is a very definitive word.
    I have never met anyone that actually possess the skill, ability and physical strength to completely hand-rub an entire car when the words HAND RUB mean to abrade the surface to level it and thus remove swirls and scratches.
    I always say it requires more skill, knowledge and muscle to remove swirls out of modern clearcoats by hand than it does to so by machine.
    In order to be effective, you are gong to want and need a machine polisher. The simplest and easiest tool to learn how to use and master is a simple 8mm free spinning random orbital polisher. Below is my recommendation and my article that has more information on the topic of a simple 8mm free spinning polisher plus the backing plates and pads to use with this type of tool than you can find in any other single page on the entire world wide web.
    Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
    Griot's Garage 6" ROP - Standard cord
    Here's the backing plate to get
    Lake Country 5" Backing Plate
    Here's the pads to get
    6 inch Buff and Shine Uro-Cell Pads
    Get the yellow pads to start with. These are "polishing" pads. If you have the budget, then add some maroon cutting pads and a few of the white finishing pads. The "polishing" pads are the most commonly used pads especially with one-step cleaner/waxes.
    And if you want to make machine polishing your car 100% absolute Bubba-Proof, get a quart of this for all your cars.
    BLACKFIRE One Step
    See my review here and look at the before and after pictures - all from one product.
    Review: BLACKFIRE One-Step Cleaner/Wax by Mike Phillips
    Play with the GLARE products but my guess is, they are mediocre at best. Maybe donate them to someone.
    Hope that helps...
    Hi Mike,
    Thanks for your thorough response to my post. Especially thankful for the recommendation for the spinning random orbital polisher by Griot. I am brand-new to detailing my cars and I am excited to learn as much as I can. I wish you could bring your class to Alaska!
    I agree the GLARE website is very cheesy and not user friendly at all, very hard to navigate and it feels like a throwback to the 90's. I am surprised you haven't given their products a try yet. The only reason I went with GLARE is because I had my 2005 scion xb professionally detailed at a shop in Hot Springs, Arkansas and the detailer used GLARE and swore by them. The results on my Scion were surreal, outstanding, life-changing, amazing, mind-blowing and three years later (with the scion sitting in an outside lot for 2.5 of the three years, with a dead engine) the Scion still looks like it came fresh off the detailing lot, it is still in fantastic shape. As a point of reference, I have never had any of my vehicles professionally detailed by ANY product, so I don't have a frame of reference from which to compare.
    From my limited understanding of the product, there is a chemical in the GLARE that forms a cohesive chemical bond with the paint. I don't know, but according to the cheesy-painful website, the lifespan of one detail job is 5 years. I would love to see a professional like yourself try it out and share your professional opinion with the rest of us, with all due respect. I will go into it with low expectations, yet it is hard for me to forget my direct personal experience of GLARE on my Scion xb. I'll see if I can recreate the magic and I will share the results here.
    Perhaps even the process is different, yet I am wary of hand polishing an entire car, much less two. So, I think a random orbital polishing tool (I apologize if I am getting the name wrong) would be a smart bet for me. On a side note, I just realized my neighbor has been detailing a car outside our apartment building and has been using a tool to grind and polish and he even did a coat of paint out there, which is crazy. (not in that order)
    I am so impressed by this forum, by your depth of knowledge and willingness to share your knowledge and expertise. Thank you so much for your generosity and for allowing me to be in this forum space. I really appreciate it, as I am so brand spanking new to this entire world and I am going to be depending on this forum to get my bearings and make it through my very first detailing job. I'm so excited.
  7. #17
    Jun 2019
    Also....
    We recently had a long-time employee retire from Autogeek. She was one of the longest working members of our family here at Autogeek. Here name was Anna.
    She also had recently purchased a Chevy Spark, of which I used for a number of different detailing articles so I'm somewhat familiar with the car.
    Water Beading from SONAX Polymer Net Shield
    And for what it's worth, while I wrote the article I'm not into water beading, I wrote it for the masses that are into water beading.
    This is awesome! I have so much to learn. I have a Spark that looks just like this, but light blue. Thanks again!
  8. #18
    Jun 2019
    Thank you so much for all of this, I am pretty overwhelmed by all the support and guidance. Very humbling. Thanks.
  9. #19
    Jun 2019
    Hi,
    Thanks for the welcome. I hope that after I get my three cars detailed I will have skills to offer my detailing to family, friends and possibly as a side business (if I like the whole process and experience). I grew up in Fairbanks and live in Anchorage, Alaska. I think the main reason I want to detail my car is because of all the problems we have with rust up here, I am hoping to circumvent that.
  10. Thanks BillE thanked for this post
  11. #20
    Quote Originally Posted by akumatu View Post
    Hi Mike,
    This forum and my work on it are an extension of our customer care department. I'd say most people don't see it that way but if you think about it - it's kind of the same thing.
    We have people that call our 1-800 phone number and ask our customer care staff detailing and product questions and they get great help and some people choose to join our forum and do the same thing. Typed-out answers tend to endure over time and are seen by tens of thousands of people for decades while phone calls are a tick more limited but both methods get the job done.
    Now that would be great. Hawaii too....
  1. Greetings from Alaska
    By Shooterf15 in forum Introduce Yourself
    Last Post: 03-09-2015, 09:46 PM
  2. Hi from Fairbanks Alaska!
    By billboard2001 in forum Introduce Yourself
    Last Post: 09-16-2013, 12:37 PM
  3. Hello from Alaska!
    By mirrorrorrim in forum Introduce Yourself
    Last Post: 05-20-2013, 11:24 AM
  4. Hello from Alaska
    By Truitt in forum Introduce Yourself
    Last Post: 12-28-2009, 08:29 PM
  5. Greetings from Alaska
    By chilly in forum Introduce Yourself
    Last Post: 07-02-2009, 07:23 PM
