Originally Posted by
SWETM
Welcome to the forum!
If you use a 1-2oz of a APC to your bottle of the foamcannon. Foam out the half of it and let the rest dwell for 10 minutes. And foam it out on your driveway or something else really dirty. Then after the 10min foam out the rest of the bottle remains. Make sure it's on the highest setting with the most chemical dilution and thickness setting. Then rinse out the foamcannon bottle and fill it with only water and foam it through the foamcannon till the bottle is empty. And do this with the water only after every use of the foamcannon. Then you know you don't have any dried up soap in the foamcannon the next time you use it.
