Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Apr 2013
    379
    Video: How to do a MAINTENANCE WASH on a ceramic coated car!!
    Hi guys!
    After the success of my video on how tu apply a ceramic coat to a car, I present you a video on how to do a proper maintenance wash of ceramic coated cars.
    Enjoy the video!
    In English:
    https://youtu.be/yLiePQRMFc8
    In French:
    https://youtu.be/mo_uYsqQ4JY
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Video: How to do a MAINTENANCE WASH on a ceramic coated car!!
    Nice vid OrangeVee and nice ride.
    Apr 2013
    379
    Thanks!!
    Nov 2015
    Los Angeles, California
    13,765
    Excellent demonstration. I like how you've stepped up to the proper dedicated products and brushes as far as the wheels & tires. You used an ideal soap... I even squeegee the windows immediately after a wash the same way. Dry the same, blow dry the same way too and use a water based tire dressing. Spot on.
    Apr 2013
    1,266
    Great stuff Pan ! Nice that you used multiple brands and obviously are not getting paid off by certain companies to put their products in a favorable light
    I can tell you do this with passion and pride
    Keep them coming I know a lot goes in to them cheers buddy
    Super Member evo77's Avatar
    Mar 2008
    582
    You should use the "Insert Video" option and instead imbed your videos into your posts for easy viewing. Just be sure to remove the "s" from https. Because links to videos can be blocked by employer computers, including mine.
    Super Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    884
    Pan - this is your best video to date. I especially liked you showing the whole process via time lapse. Well done sir!
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
    Sep 2015
    6,281
    Drying from bottom to top would scratch the finish.Way to many chemicals on the brake components and I see no lather in the video.I personally would do at least the bottoms.Nice video and thanks for the time and effort.
    Nov 2015
    13,765
    Quote Originally Posted by GSKR View Post
    As far as the drying: There would have to be dirt/grit on the paint in order to cause any scratches.. But that's not the case since he just finished washing and rinsing the car with a power washer.
    Which 1 of those chemicals harmed the brakes? I didn't see any risks.
    There's alot of people who are of the belief that suds aren't so important, and it's what's in the wash solution that matters.. Just take every rinseless wash for example, no suds/lather, and works fine.
    ...If anything, he missed doing anything to the wheel wells.. I would've at least sprayed them real quik with some APC and gave them a rinse with the power washer and then sprayed some water based dressing on them after the wash.
  10. #10
    Apr 2013
    379
    Thanks I appreciate it!
  1. Replies: 3
    Last Post: 12-09-2019, 04:28 PM
  2. Noob! Help with ceramic wash/maintenance.
    By vilastrex in forum Auto Detailing 101
    Last Post: 08-30-2019, 12:58 AM
  3. Ceramic coated maintenance advice needed
    By Landtosea in forum Auto Detailing 101
    Last Post: 06-20-2019, 04:00 PM
  4. PM Question about your maintenance wash for a coated vehicle
    By The Guz in forum Auto Detailing 101
    Last Post: 08-24-2018, 09:02 PM
  5. Video Tutorial - How To Do a Maintenance Wash
    By Wills.WindowsAndWheels in forum Auto Detailing 101
    Last Post: 11-13-2017, 12:27 PM
