Page 17 of 49 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 484
  1. #161
    Feb 2012
    Palatine Illinois, USA
    24,532
    Re: Video: Trying P&S Bead Maker for the first time.
    I'm sure I'll get a gallon around Christmas time, along with a couple itemsVideo: Trying P&S Bead Maker for the first time.
    2022 Elantra N Cyber Gray
  2. #162
    Sep 2017
    Sweden
    3,022
    If you used as a stand alone LSP you where recommended to apply heavy. And when used as a drying aid or topper the 1-2 spray per panel. Or are you needed to heavy application even if you have a LSP on the paint the first use?
  3. #163
    Mar 2017
    Southeastern PA
    2,480
    Apparently apply heavy the first time regardless of what is underneath. Matt Moreman from Obsessed Garage showed how and applied heavy on top of an Audi R8 that was recently coated with Gtechniq CSL.
    Bruno Soares
  4. Likes SWETM liked this post
  5. #164
    May 2017
    Pittsburgh PA
    2,847
    Still can’t picture using 6-8oz for an application without 2/3 of it dripping off.
  6. #165
    Newbie Member Tarheelplayr5's Avatar
    Aug 2018
    When i applied it for the first time, it was on top of CSL on my truck. All i did was mist the entire panel to ensure it was covered. It wasn't to the point of product running off the panel. To me, you're wasting product if it's that saturated to the point of run-off. But i let the product sit on whichever panel i was working on for about a minute. Then i wiped the panel off with a microfiber. I went around the entire truck using this method and then when all was done, i went back through with a clean, dry microfiber and buffed off the little bit of streaking that was left behind. My philosophy was to let the product "bond" to the surface a little bit before wiping it right off. I'm only about 2 weeks with this product being applied but it's holding up to PA's nasty salt-covered roads so far.
  7. Likes Klasse Act liked this post
  8. #166
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Quote Originally Posted by Tarheelplayr5 View Post
    So how many ounces did you use?
  9. #167
    Aug 2018
    I'd say 3. Maybe 4 at the most. 2017 crew cab f150 regular bed.
  10. #168
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Me neither!
    Quote Originally Posted by BSoares View Post
    with Gtechniq CSL.
    I’m wondering then:
    Is “thin”...no longer “in”?!?!
    If so:
    Then I’m going to wager that a person could
    utilize most any other Spray-On/Wipe-Off paint
    Sealant in a similar: ‘heavily-applied-manner’...
    and come up with results that are nearly
    indistinguishable from those of the “Bead Maker”.
  11. Likes DetailZeus liked this post
  12. #169
    Feb 2012
    24,532
    I agree about NEVER oversaturation of a panel to where it's running off the panel, common sense hereVideo: Trying P&S Bead Maker for the first time.
  13. #170
    Apr 2013
    379
    For the first application, you just want to saturate the panel enough before getting to the point of it running off. It actually "sticks" to the panel quite well. I applied is using an IK Multi 1.5 pump sprayer. You use a slightly damp microfiber towel (damp with Bead Maker) for the initial wipe, and then come in with a second clean and dry microfiber towel to buff off.
    If you work in more humid environments, apply more product to the towel, less on the paint (as per P&S directions when I spoke with Dave Phillips, the chemist).
  14. Likes Klasse Act, MadMerc, SWETM liked this post
  1. Replies: 17
    Last Post: 01-05-2021, 07:04 PM
  2. Bead Maker
    By PaulMys in forum Auto Detailing 101
    Last Post: 08-12-2019, 09:17 PM
  3. Bead Maker?
    By abileneautoworx in forum Auto Detailing 101
    Last Post: 01-10-2019, 07:11 PM
  4. Bead Maker on glass....
    By Firehouse Mike in forum Ask your detailing questions!
    Last Post: 12-30-2018, 03:59 PM
  5. Video: Part 2: P&S Bead Maker tutorial and review!
    Last Post: 11-18-2018, 02:11 PM
