Page 6 of 6 FirstFirst 123456
Results 51 to 54 of 54
  1. #51
    Junior Member mujahdi's Avatar
    Mar 2012
    decatur, ga
    55
    Re: Astro Van Mobile Set up
    Quote Originally Posted by Kristopher1129 View Post
    It may pump water just fine...but you don't want overkill. Plus, if it isn't a demand pump, it's just gonna keep pumping. You'd have to manually shut it off when you release the trigger of your pressure washer.
    Does it shut itself off with back pressure? If not, you may just have a utility transfer pump. More so meant to transfer water out of basements and such.
    yes it just pumps not demand so i have to manually shut it off this will hold me til i get the better pump i need it was 30 bucks so i figured it was a good price for it also could use it to unflood someone basement or something in case of emergency try to get a couple dollars on the side
  2. #52
    Feb 2012
  3. #53
    Super Member 215Detailing's Avatar
    May 2011
    1,063
    Quote Originally Posted by BobbyG View Post
    WOW, you have put together a really nice setup! I'm very impressed with how professional and well thought out your rig is...
    Congratulations and good luck with your business!!
    Nice unit how are things currently working with your setup?
  4. #54
    Super Member TFTADetail's Avatar
    Apr 2015
    Austin, TX
    319
    Quote Originally Posted by JohnHenry View Post
    Don't know how much experience you have, but I would be very careful with a 3000 PSI pressure washer. Good for driveways, dangerous on paint.
    Pressure is easily adjusted down with the throttle.
    No worries.
    The Finishing Touch Auto Detail, LLC
    Serving Austin, TX | San Antonio, TX | Portfolio | Reviews | Contact Us
  1. Astro van setup
    By alphacharlie65 in forum Auto Detailing 101
    Last Post: 11-11-2015, 03:00 PM
  2. My Astro Van Set up
    By Detailing by M in forum Auto Detailing 101
    Last Post: 05-03-2013, 01:11 AM
  3. How do you strap things down in an Astro van?
    By ShineTimeDetail in forum Off-Topic
    Last Post: 05-24-2011, 12:52 PM
  4. What is an Astro drum polisher??
    By ExoticAutoDetai in forum Rotary Buffers
    Last Post: 01-04-2011, 11:19 PM
  5. Detailed A Astro Van
    By scottgt in forum Show N' Shine
    Last Post: 04-10-2007, 08:00 PM
