Results 1 to 4 of 4
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    2016 Mercedes-Benz C300 B-Pillar: HOW DO I???
    I currently have Rupes Yellow pads Meguiar’s MF cutting pad
    M100
    M205
    Do I have what it takes to polish these scratches on the B-pillar?
    Is this doable for this vehicle?
    Also,
    Also, I don’t know if this matters but, I read somewhere on this forum about the do’s and dont’s on Mercedes paint.
    And I was told I can find the paint code on this. What am I looking for first of all?
    And second, with the material I have, can I safely polish out this vehicles paint.
    I don’t know if this makes sense. Again, I’m asking this based on something I read about Mercedes paint and I want to play it safe.
    Thanks.
    Feb 2014
    Rochester MA
    2,627
    Re: 2016 Mercedes-Benz C300 B-Pillar: HOW DO I???
    The paint code is the 040 number on the black tag. If there was a C in front of it that would indicate factory Ceramic clear which is pretty hard. But don't think they do it anymore. I check all the Mercedes for it regardless.
    As for polishing those pillars I would use m100 microfiber cutting pads followed by m205 on a yellow pad and if needed a soft finish pad. I typically use my Adams swirl killer mini 3in 12mm throw for areas like this.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
  3. Likes Flash Gordon liked this post
  4. #3
    Jun 2014
    Chandler, AZ
    3,360
    Exactly what Justin said. Here is the article he's referring to:
    Ceramiclear Paints - Be Careful
    Those B-Pillers will polish up really nice. You may not even need 100... Start w/ 200 first. If you're doing the entire vehicle with 100, then yes, hit those... but do them last... or at the last cycle of your pad prior to changing out. The pads can hit the rubber and turn black really quick. They'll clean up, but you don't want to go back over paint with them after.
  5. Thanks Dan Tran thanked for this post
  6. #4
    Super Member Cosmin's Avatar
    Oct 2009
    Austin TX
    742
    best way is to wrap them in ppf , self healing this days saves a lot of headache.
    can be polished instead? yes , but are plastic and the clear on them is thinner than on the paint, plus you need a smaller pad , that usually will generate more heat ....
    i may be wrong , but i seen older german cars with pillars faded or clear coat failure on pillars....
    Detail Luxury and Exotics in Austin area
    @proreflection
    www.proreflection.com
  1. 2016 Mercedes Benz S550
    By Sizzle Chest in forum Show N' Shine
    Last Post: 01-25-2021, 08:19 PM
  2. Mercedes Benz C300 Questions
    By nprotz in forum Auto Detailing 101
    Last Post: 06-23-2019, 09:07 PM
  3. 2010 Mercedes Benz C300 \\ Exterior Detail
    By JSou in forum Show N' Shine
    Last Post: 12-07-2013, 11:58 AM
  4. Mercedes Benz C300 correction and Opti-Coated
    By Evan.J in forum Show N' Shine
    Last Post: 07-09-2013, 10:16 AM
  5. Mercedes Benz C300 by Advanced Detailing of South Florida
    By Advanced Detailing in forum Show N' Shine
    Last Post: 11-11-2011, 05:25 PM
