Re: Pressure that draws water from a tank
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Monsterdetail
I would be running 100-150 gallon tank in a trailer. So if i go with a pump setting i would have to figure away to run a battery in the trailer to power the pump correct?
Lots of different ways to do this, including the 12V outlet in your vehicle. I ran a 12V outlet to the bed of the truck. I also have a 120V harbor freight clear water pump. It is cheaper than the 12V. In that case, I use a power inverter to convert the DC from the battery to AC for the pump. I use the 120V pump to pump waste vegetable oil, which I use to fuel the diesel truck.
Kirk Harrod's Mobile Detailing, Frankfort, KY
Official Detailer of Camarofest 8 & 9
No one has detailed more Camaros.
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Upwardly Mobile Detailing
I don't get how being a pro means buying a pump. I'm a pro and I bought the right pressure washer for the setup. I would think you would look less like a pro cause you have to rig something extra up to get your pressure washer to work. I get saving money but you can't compare a setup to being a pro. Almost all detailers here in so cal run their setup with the right gas pressure washer with a hose line coming from the tank and another bypass hose line also so that the pressure washer can stay running even when you are not using it.
Yes I agree that you can be a pro and have different setups. I like the tank, pump, consumer pressure washer set up, for me, because if I have a pressure washer go down, I can just grab one from the store to finish the job.
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by KirkH
So will this work...
I would get a 6 prong cable for the truck to the trailer
From the cables on the trailer I would run a 12v battery
Battery to a inverter
Pump to inverter
100-150 gallon tank to pump
Pump to say I got a karcher k5 and hook it up to 12v outlet that I create in the trailer or generator
Would this set up work or am I still missing something
Sorry about the newbie questions guys but I appreciate all the help
Pump to inverter
You need to use the battery on your vehicle since it will be recharged by the alternator. If you just set a battery in the trailer and run from it, it will run down quickly and also affect the life of the battery. Depending on your vehicle, there are options, like a second alternator for the auxiliary battery.
"Rig?" Installing an inline pump in a manner that it was designed to be used now constitutes rigging something up? I'll be sure to notify the good people at Merrian Webster that you've redefined the word "rig." I'm in SoCal. All the detailers I know run a pump. Let me restate that. All the detailers I know that look like somebody you would actually want working on your car. Because that's the reality. Perception is everything. But, hey, anytime you want to bust out photos of your setup, I'll bust out photos of mine and we'll see if it looks "rigged."
Oh, and you have Testimonials misspelled on your website.
Dual Battery Systems | Alternator charging, how it
should be done
Would doing something like this work? or using some type of solenoid? I am just trying to figure out how most of you guys are running a pump. Do you leave your vehicle on the entire job just to keep the battery charged to power the pump?
Auxiliary battery and alternator is the ideal situation.
You can run the pump off the battery as long as you have a good battery. My truck is a diesel and has 2 batteries so I have plenty of juice to start the truck after the job.
SHURflo 2088-594-154 On-Demand Diaphram Pump, 3.3 GPM @ 45 PSI, 115V I was looking at pump like this and then just plugging it into a 4000w generator, so I can avoid running this battery cluster ####. I am using a dodge 1500 right now till we can get money to get a diesel.
Will definitely work if you have a generator. I don't run a generator. I will have to buy one for a big job I have coming up in July.
Thank God does that solve a lot. So what do you guys think about the karcher k5 with that pump to a 4000 w generator or is 4000 not enough to power a pw and a pump?
By 2modfast in forum How to make money detailing cars
Last Post: 01-05-2017, 01:46 PM
By Mattdamobster in forum Auto Detailing 101
Last Post: 09-12-2016, 06:12 PM
By 215Detailing in forum Off-Topic
Last Post: 11-27-2015, 03:35 PM
By jarred767 in forum Auto Detailing 101
Last Post: 11-14-2014, 08:04 PM
By KJW Detailing in forum Auto Detailing Tools and Accessories
Last Post: 11-26-2012, 06:27 PM
