This is EXACTLY what I was talking about in the other thread where the guy had a bad pump. You want to be a professional. Buy professional tools. You have to add a pump. You've had several pros tell you that it will work but it won't work good. The pressure washer will occasionally sputter. You'll need to keep the flow from getting interrupted by the lack of drop in the hose, the pressure will drop when the tank empties. All of these things are controllable in your driveway, not on a jobsite. BUY A PUMP. You want to be a pro, look and act like a pro. A Shurflo pump you need is less than $60 on Amazon
