View Poll Results: What's the number one most important factor when it comes to polishing paint?
Voters
337. You may not vote on this poll
  • Technique
    186 55.19%
  • Tool
    10 2.97%
  • Pad
    8 2.37%
  • Paint
    43 12.76%
  • Abrasive technology
    90 26.71%
Page 16 of 21 FirstFirst ... 6789101112131415161718192021 LastLast
Results 151 to 160 of 208
  1. #151
    Super Member 57BORNTORUN's Avatar
    Jul 2012
    Palm City, Florida
    1,554
    Re: POLL - What's the number one most important factor when it comes to polishing paint?
    Quote Originally Posted by Dandy98
    "Coming from 35+ years solely in the abrasive business I favored abrasives.
    If you do not have uninform mineral displacement that is consistent with every yard of sandpaper coated no matter your skill set you will be working longer and harder to get the inconsistent finishes out in the next step"
    And with this statement I say, I will never use poor quality sand paper , discs or bands when polishing stainless steel trim to a mirror finish and expect the same results as more expensive products.
    Sanding body work is less critical in it`s early stages then switched to higher quality more consistent grits.
    Nothing worse than seeing sanding marks under paint due to poor prep.
    "Chrome wheeled, fuel injected and steppin' out over the line"
  2. #152
    Super Member axel06's Avatar
    Oct 2012
    Fords, NJ
    883
    Quote Originally Posted by 57BORNTORUN View Post
    "Coming from 35+ years solely in the abrasive business I favored abrasives. If you do not have uninform mineral displacement that is consistent with every yard of sandpaper coated no matter your skill set you will be working longer and harder to get the inconsistent finishes out in the next step"...Dandy98
    And with this statement I say, I will never use poor quality sand paper , discs or bands when polishing stainless steel trim to a mirror finish and expect the same results as more expensive products.Sanding body work is less critical in it`s early stages then switched to higher quality more consistent grits.Nothing worse than seeing sanding marks under paint due to poor prep.
    100% agreed with 57borntorun
  3. #153
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,017
    Quote Originally Posted by kkritsilas View Post
    That can be flipped around as well.Take an experienced professional detailer, who knows exactly how to use a PC/DA, and the lowest end of high quality product, say Meguiars Ulitmate Compound, Polish and Wax, and have them do a 3 step correction/polish and wax. They will most likely get outstanding results.
    Take a newbie (like me) give them the best polisher available (Flex 3401, Rupes Bigfoot, GG BOSS, or whatever you believe to be the best polisher. Give them the highest quality polishes/compounds/waxes (LSP). Let them work on a car with the same paint (in terms of defects, colour and hardness). Let them work on the paint as long as they want.
    How much do you want to bet that the pro, with a low end polisher, and high quality, but fairly low end products, ends up with a better result? Not to mention that they do it faster and a more complete job?
    Both Mike's have good points. IT is the abrasives that do the job, and products with 15 year old technology are inferior to current products. However, so some extent, this misses the point. Abrasives, in and of themselves do not do a thing. They need to be pushed around with a variety of pressures, orbital/rotational speeds, and arm speeds to work properly. Technique is what does that, and allows the abilities of the products to work as well as they can. As for the 15 year old technology statement, is is completely true. However, in the detailing world, I don't see a lot of products with 15 year old technology, outside of the 3M line. Whether it be Meguiars, Mothers, Sonax, Menzerna, Pinnacle, Griot's Garage, Wolfgang, CarPro, 3D, Ultima, Optimum, or almost any other high quality product vendor, their products are constantly being improved. Within the high quality brands, if somebody has good technique, they will get good results. Some vendor's products may be better suited to a particular polisher, or environmental condition, but a person with good technique should be able to get good to great results with any vendor's products. Conversely, somebody with sloppy/bad technique, no matter how high a quality product they are using, won't get results nearly as good.
    This point was recently illustrated to me.
    Poor guy could have had magic super compound on his pad, and it would have been "applied" to the paint, rather than worked in, as the pad jiggled over the paint.
    Also, MP's point was illustrated as well once he got his technique down. Had be been using old, outdated technology, he would have struggled with that particular vehicle. At this point, he needed all the help he could get. Also, being in the production environment, there isn't time to "massage in" deficiencies with old products. The new stuff can get in, and get it done in much less time.
    In my opinion it's an equal partnership of Technique, Product, and Pad. They sort of need each other for the highest potential of success. Companies like Rupes come to mind where they give you the very best the can in tools, abrasives, pads, and suggested technique for optimal results. This is also why I admire their, Meguiar's, Griot's, etc system approach offerings .
  4. #154
    Nov 2016
    KY
    1,065
    I picked tools. You must have the correct tool for the job. Same as in any other business.
    All the other things are important. But it all starts with the tool.
    But the question is so vague it makes the answer impossible. If we are talking simply "polishing", then I might say product is "most important." But if by polishing we mean paint correction, I'm going with tool.
  5. #155
    Jul 2016
    3,328
    Just Cuz somethings old doesn't mean it's inferior, people were getting their cars shiny 20 years ago to believe it or not. Look at show car glaze. It's 100 years old and still the best glaze around. Sometimes they can even have better old products but they have to change them because it's the chemicals are no longer allowed
  6. #156
    Feb 2015
    191
    With my limited experience and an impossible question to answer with one answer, I'd have to go with paint; I think the particular paint would dictate which technique, tool, pad and abrasive technology would be best used to polish that particular paint. We are all correct , no doubt, given the question has so many variables.
  7. #157
    Jul 2016
    3,328
    Abrasive technology
  8. #158
    Just to chime in....
    Here's a tip... don't make the question difficult. Don't read into it, don't create hypothetical situations.
    When it comes to polishing paint, what's the most important factor?
    For me, I know the answer. It's simple.
    What touches the paint first?
  9. #159
    Super Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    2,243
    Easy...
    I voted---Abrasive Technology!
    Do I get a prize??? Grin...
    Tom
  10. #160
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    I voted abrasives. Here's why. For example..... if I have a heavily swirled or freshly sanded paint surface and use a super ultra fine polish, it won't matter what pad, tool, technique or paint I'm working on. It just won't work. Not sure I would say abrasive "technology" tho. I would choose abrasive "selection" to fit my thinking and thoughts.
    Tool is definitely out cuz I do hand polish areas(think under door handles)
    Technique is overrated I feel. It's end result that matters IMO!
    Paint- we can't control what we're working on. Must deal and adjust accordingly.
    Pads do matter. But not as much as the buffing liquids on them.
    Jim
  1. Replies: 14
    Last Post: 07-17-2020, 09:16 AM
  2. Vindication - What's the most important factor when it comes to polishing paint
    Last Post: 07-17-2020, 09:11 AM
  3. Car Detailing Poll - Your feedback is important!
    By Nick McKees37 in forum Auto Detailing 101
    Last Post: 02-10-2015, 12:36 PM
  4. Why Paint Cleaners are Important
    By Flannigan in forum Tricks, Tips and Techniques
    Last Post: 05-09-2012, 06:27 AM
  5. Harley Factor Bags - Paint Correction
    By crxman2010 in forum Motorcycle Care
    Last Post: 03-05-2012, 09:49 PM
