Applying Wax
Lately, I've been applying Liquid Souveran, paste Souveran, Fuzion, and 4*UPP, and they ALL have been drying clear and glossy in many areas on my vehicle where, I believe, I applied them the most evenly. It's as if, after I apply it and it hazes, it does not need wiped off. Seemingly, it dries perfectly clear, with a very high level of gloss.
Has anyone else experienced this, or is it just me?
Re: Applying Wax
Haze that is perfectly clear, with a very high level of gloss?
Your definition of haze is bassackwards from mine!
Anyway:
If you could apply these "Waxes" with the same even-ess
all over the entire vehicle---without ever having to wipe any haze:
Now wouldn't that be doing something!!
Re: Applying Wax
Not had that happen that I know of. How are you Appling them?
'Cause there's just something women like about a pickup man.
Rich
Re: Applying Wax
I apply the wax as perfect as I can, meaning perfectly even in a very thin layer. I know I'm leaving wax because I get an even haze, then move to the next part of the panel, then eventually to another panel. Then, when I go back to wipe, often it's very glossy and transparent where it was once hazy.
Am I going even further into insanity, or is PBMG's waxes and 4* sealant that good?
Re: Applying Wax
I use all those waxes and apply with buffer on a blue/black pad, they are nice even light coats, but still haze and have to buff off.
Rich
Re: Applying Wax
Try applying the wax so evenly that the haze left behind resembles the appearance as if you evenly sanded through half of the clear coat surface. Then let it sit for as long as it needs to become transparent.
Re: Applying Wax
Okay, now that football's overwith for the day, let's get back to more important things, like waxing your vehicle, and the anomolies that surface if you do it almost perfectly. Can anyone identify with what happened to me in my first post?
Re: Applying Wax
Yesterday the car got a coat of 845 since it was above 40 in the garage.
I applied it by hand in what I thought was an even coat.
After I was done, I sighted down the car and noticed sections on the doors that appeared shiny like I totally missed them.
It was all covered in haze when I viewed perpendicular to the panels.
Maybe it was the viewing angle?
Re: Applying Wax
{Bob}
Re: Applying Wax
spazzz beat me to it. I've noticed what expdetailing is trying to describe myself. And usually (in my case) the lighting was low, like in a garage in the evening with only a couple of incandescent bulbs. But looking at the panel at an angle, it's obvious the product is still there and that I've actually missed a couple of spots! This was years ago though, I now know better to work with better lighting!
Last Post: 06-29-2017, 02:43 PM
By main pft in forum Auto Detailing 101
Last Post: 05-24-2014, 02:55 PM
By FMINUS in forum Auto Detailing 101
Last Post: 05-20-2007, 05:32 PM
By richy in forum Auto Detailing 101
Last Post: 05-19-2007, 10:13 AM
By ZmZoom6 in forum Auto Detailing 101
Last Post: 09-18-2006, 05:50 PM
