Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Regular Member MNDSMtuner96's Avatar
    Sep 2012
    148
    Paint thickness gauge
    Just got a paint thickness gauge and am new to measuring paint. The one I have is just a cheaper one that measures all three layers. Just wondering, what's your rule of thumb when it comes to measuring paint thickness? How do you know if you can or can't wet sand/compound? Any advice is much appreciated!
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Paint thickness gauge
    Quote Originally Posted by MNDSMtuner96 View Post
    I have wet sanded a new trunk on a Nissan that I thought was safe to wet sand (120 microns) and burned through using 2000 grit sand paper. Wet sanded may cars in the past, but it only takes one strike through to make you weary.
    Super Member builthatch's Avatar
    May 2008
    east coast
    2,352
    it's impossible to know for sure. massive experience gives you an index in your head, so you end up knowing what years of what makes with what models made in what factories come with what sort of thickness...but other than that, it's so hard to know for sure.
    some people say they use the door jambs as a guide for clear - the theory is that the jambs have the least amount of clear so you can loosely compare and contrast that measurement vs. your exterior panel to gauge.
    i have a DFT Combo gauge and what i've found is that it's most useful to help quantify how much work you've done. you can go around on a given panel and get an idea of what the panel has...maybe compare it vs. similar panels on the car and get an idea of where it should be to start. plus that can help detect if your panel is particularly higher or lower vs. the others.
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Note:
    µ = microns
    The following are some of the coating industries' current average
    thickness-standards, that have been adopted at many OEM's paint kitchens.
    ______________________________________________
    E-coat.............1.0-1.2 mils = 25.4µ--30.48µ
    Followed by:
    •Primer Surfacer...~1.2 mils = ~30.48µ
    •BaseCoat........0.4-1.0 mils = 10.16µ--25.4µ
    •ClearCoat........1.4-2.2 mils = 35.56µ--55.88µ
    Total..................3.0-4.4 mils = 76.2µ---111.76µ
    Add E-Coat.......1.0-1.2 mils = 25.4µ---30.48µ
    Total Thickness..4.0-5.6 mils = 101.6µ---142.24µ
    Now:
    In order to stay within OEMs' paint warranty recommendations:
    •CC removal: no more than: 0.3-0.5mils = 7.62µ--12.7µ
    So...Using the above #s:
    If the starting EPTG measurement reads: 4.0 mils/101.6µ...
    Then:
    At the end of all of the sanding/compounding/polishing steps, (while the vehicle's paint is under warranty), the EPTG measurement should be no less than: 3.5mils = 88.9 µ
    -IMHO...
    When it comes to certain "paint correction" steps:
    Extreme Caution should be exercised when EPTG readings are anywhere near the low end of the spectrum!!
    YMMV.
    Sep 2012
    148
    Thanks guys. What's an "E" Coat?
    May 2008
    east coast
    2,352
    it's like powder coating but with paint. they charge the components so they are attracted to each other. they can help control a lot of aspects of the finish by manipulating the voltage.
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Bob,
    Where are those numbers from?
    I have not seen it stated so definitively before
    Kyle
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by allenk4 View Post
    Bob,
    Kyle
    My friends over at BASF and DuPont!
    Food for thought.
    Talk about trouble determining total paint thickness:
    How many EPTGs, that can measure 3 film layers, will become anachronistic...when all of the OEMs start incorporating the primer/color-coat?!?!
    Sep 2012
    148
    How many manufacturers use the E coat?
  10. #10
    May 2008
    east coast
    2,352
    Quote Originally Posted by FUNX725 View Post
    Food for thought.
    i don't think that will change anything other than the standards for what we expect to see when we measure...until it becomes common knowledge that X automaker is doing that.
    if a gauge can measure three individual layers, it will then show two in your scenario. if that combo happens (don't know anything about it), then hopefully they will have gauges that can read indiv layers on AL and steel panels in the first place lol
  1. PTG - Paint Thickness Gauge
    By JohnnyRocket in forum Ask your detailing questions!
    Last Post: 03-07-2018, 02:23 PM
  2. Paint thickness gauge
    By Hllywd in forum Hot topics & Frequently Asked Questions
    Last Post: 05-10-2016, 10:32 AM
  3. Replies: 8
    Last Post: 02-29-2016, 10:54 PM
  4. Paint Thickness Gauge
    By kevin_1981 in forum Auto Detailing 101
    Last Post: 07-23-2014, 05:29 PM
