Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
Hybrid View
  1. #1
    Newbie Member scohen500's Avatar
    Join Date
    Sep 2014
    Posts
    3
    Post Thanks / Like
    Help: Window Cleaner
    My back window has what looks like water stains that I cannot remove. I can use some help please.
  2. #2
    Regular Member OCD Detailing's Avatar
    Join Date
    Jul 2014
    Posts
    167
    Post Thanks / Like
    Re: Help: Window Cleaner
    If you have a buffer you can try that. I use the Griots glass polishing pads. I have also read vinegar can help.
  3. #3
    Super Member wdmaccord's Avatar
    Join Date
    Jun 2013
    Location
    West Des Moines, IA
    Posts
    1,278
    Post Thanks / Like
    What have you tried so far? Along with what OCD mentions, you could try claying also.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
  4. #4
    Newbie Member Cudjoe Bill's Avatar
    Join Date
    Nov 2014
    Posts
    5
    Post Thanks / Like
    Here are the steps I use
    1) stoners invisible glass. Get the glass wet
    2) use a razor blade to get most of the gunk off. The stoners acts as a lubricant. This will remove any bug guts etc
    3) dry window with a glass cleaning micro fiber towel
    4) using a micro fiber polishing pad polish the glass with Gel-Gloss kitchen and bath cleaner and polish (ACE hardware), or you can use Bonami (make a paste). The key is to polish still the surface is smooth. You will feel any etching as you polish, keep going still it no longer grabs or squeaks.
    5) wipe off polish residue with a microfiber (medium nap)
    6) clean the glass with stoners. Use 2 glass micro fiber towels (the shorter the nap the better). Saturate one towel, wipe down the glass, immediately use the other towel to wipe and polish off the stoners (if the dry towel sticks, just go slower - let the microfiber do the work). It is easiest to do the edges first and move to the center.
    If you are going to do a glass coating...
    7) take your dry towel and saturate it with IPA (15%). Wipe down the glass and dry / polish with another glass microfiber towel. This will remove any wax and decontaminate the glass in preparation for a coating. I do the when ever I wax the car to make sure the glass stays clear. Be careful doing this as the IPA will remove your wax - stay on the glass.
    8) Apply your coating
    9) clean the inside of the class using step 6
    Hope this helps. I hate dirty glass. If anyone has suggestions on improving my technique, please let me know..
    Just did this today (sorry picture is upside down)
    Attached Thumbnails Attached Thumbnails Help: Window Cleaner-image-jpg
  5. #5
    Super Member dpk20x's Avatar
    Join Date
    Mar 2012
    Posts
    748
    Post Thanks / Like
    Is this on your corvette? Is the back window even glass?
  6. #6
    In time out
    Join Date
    Mar 2013
    Location
    Los Angeles, CA
    Posts
    4,845
    Post Thanks / Like
    Try a cleaner wax 1st
    Simple and works often
  7. #7
    Regular Member rockinrandall's Avatar
    Join Date
    Dec 2011
    Posts
    120
    Post Thanks / Like
    sounds weird but, Bar Keepers Friend is an old trick. Removes water spots and streaks pretty well.
  8. #8
    Super Member KMdef9's Avatar
    Join Date
    Jan 2014
    Location
    The Motorcity
    Posts
    789
    Post Thanks / Like
    Steel wool 0000 could help too if you don't have a razor blade, polisher, etc.
    Spray a 2X2 area with window cleaner, like stoners, and rub the steel wool back/forth and up/down several times. Wipe off, move next area.
Similar Threads
  1. Replies: 0
    Last Post: 12-27-2015, 12:15 PM
  2. What's everyone's go to window cleaner
    By Mercedes350 in forum Ask your detailing questions!
    Last Post: 09-22-2013, 03:16 PM
  3. Window Cleaner- What's the best?
    By RcAutoDetailing in forum Products Guides
    Last Post: 01-13-2012, 05:56 AM
  4. window cleaner
    By waxman1 in forum Auto Detailing 101
    Last Post: 11-10-2011, 03:47 PM
  5. window cleaner
    By spitshine1 in forum Auto Detailing 101
    Last Post: 05-25-2011, 03:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
